1. Re: Mercalli V2 analysis problem
Alan Craven Oct 17, 2010 1:07 AM (in response to Robbie75VR)Are you adding transitions to your clip after the Mercalli analysis? If so, that is is the cause of your problem - it is noted on the ProDad website in the FAQ. They recommend always applying Mercalli after anything else.
2. Re: Mercalli V2 analysis problem
MermaidBeacher Oct 17, 2010 1:08 AM (in response to Robbie75VR)If you have a video transition on the clip, for example a disolve, you will have to remove it first then run Mercalli V2 again then you can redo the transition
3. Re: Mercalli V2 analysis problem
Robbie75VR Oct 17, 2010 1:16 AM (in response to Robbie75VR)My clips have equalize effect and cross dissolve, applied before mercalliv2, strange I was using mercalli with Sony Vegas Pro 9 and there you don't have to remove transitions or effects... I'll try to do as you say in a minute and see...
4. Re: Mercalli V2 analysis problem
MermaidBeacher Oct 17, 2010 4:55 AM (in response to Robbie75VR)You only have to remove the cross disolve before reapplying the Mercalli V2.
5. Re: Mercalli V2 analysis problem
Robbie75VR Oct 17, 2010 6:35 AM (in response to MermaidBeacher)so the correct workflow is:
edit
apply mercally
prerender
view
or
edit without crossfades???
apply mercally
apply crossfades
prerender
sounds very unpracticle to me.. ?
Thanks for your help
6. Re: Mercalli V2 analysis problem
MermaidBeacher Oct 17, 2010 5:10 PM (in response to Robbie75VR)edit without crossfades
apply Mercalli V2 to your clip
render the clip to ensure a smooth playback
play the clip back to make sure that you are satisfied with the result
apply any crossfades
If you then decide to shorten or lengthen the clip you must then remove the crossfades, reapply Mercally V2, then add the crossfades again.
Colour changes you may have made to the clip are not affected and don't need to be removed or reapplied, it's just the crossfades.
7. Re: Mercalli V2 analysis problem
Robbie75VR Oct 18, 2010 2:39 AM (in response to MermaidBeacher)It must have been some bug because now I can freely edit my crossfades and my analysis remains valid, as it happens in Sony Vegas. Maybe it was its wrong day.. ;-)
Now I can do a complete edit then stabilize with no problems...
The only action that requires a new analysis is when I edit the start or end point of the clip, that sounds very reasonable...
Now I only have to understand when this "bug" happens...
8. Re: Mercalli V2 analysis problem
Greuter13 Oct 20, 2010 11:15 PM (in response to Robbie75VR)The current Mercalli version (Windows) 2.0.69, (Mac) 2.0.70 works better with transitions.
The improvement is a workaround to fix a Premiere CS4 and CS5 Bug.
Is the workaround activated a warn-symbol is visible in the UI. Click on this to get a message.
The opposite:
Mercalli can’t detect clip trimming correctly.
Tip:
If the start point was trimmed than the stabilization will breaks.
For a steady output, the user must open the Mercalli UI and press the “OK” button to reanalyze.
I have done same tests with transitions and all works fine!
9. Re: Mercalli V2 analysis problem
Alan Craven Oct 20, 2010 11:32 PM (in response to Greuter13)function(){return A.apply(null,[this].concat($A(arguments)))}
The opposite:
Tip:
Could you tell us how we get updates with the new version? The old Service Pack system does not seem to be there for Mercalli 2.
10. Re: Mercalli V2 analysis problem
Robbie75VR Oct 20, 2010 11:54 PM (in response to Alan Craven)simply by clicking the original link you had when you purchased mercalli, they upgrade the file at the same address.
11. Re: Mercalli V2 analysis problem
Alan Craven Oct 21, 2010 5:22 AM (in response to Robbie75VR)function(){return A.apply(null,[this].concat($A(arguments)))}
That method will update the installation files in situ.
So we cannot download and save the actual patch file then?
12. Re: Mercalli V2 analysis problem
Robbie75VR Oct 21, 2010 5:29 AM (in response to Alan Craven)they just give you the new installer, that can be installed over the old one, without uninstalling it first... at least that worked with me.
13. Re: Mercalli V2 analysis problem
Alan Craven Oct 21, 2010 5:53 AM (in response to Robbie75VR)Ah!!!
It is easy once you try it!!
Running the original download manager leads to an installation screen which offers the option to save the download as a zip file of 10-12 MB.
