1. Re: BR error:not enough free storage code 25
John T Smith Oct 14, 2010 9:57 AM (in response to h2ofun)1st, make sure you have not added anything to the ROM content area, like a large file or a directory
Then, some reading (and you should post your version)
Encore space recovery http://forums.adobe.com/thread/646383?tstart=0
Encore is 32bit http://www.adobe.com/products/premiere/encore/
Odd Errors http://forums.adobe.com/thread/670174?tstart=0For CS4 you must update the Roxio component http://forums.adobe.com/thread/400484?tstart=0
More on Encore and Roxio http://forums.adobe.com/thread/528582?tstart=0 or direct to
http://kb.roxio.com/search.aspx?URL=/content/kb/General%20Information/000070GN&PARAMSPlus, Long File Names or odd characters Cause Crashing http://forums.adobe.com/thread/588273
And #4 Here http://forums.adobe.com/thread/666558?tstart=0
And This Message Thread http://forums.adobe.com/thread/665641?tstart=0 -
2. Re: BR error:not enough free storage code 25
h2ofun Oct 14, 2010 1:21 PM (in response to John T Smith)I have 6 projects that are exactly the same structure. 4:35 length in time. 4 menus. No ROM content. CS5 version.
For 5 of the projects, both the BR and DVD work just fine. But this one only works on DVD.
I have looked into the BDMV folder, and found the TS file it made, only 23 gig so way away from 50.
In the past I could restart the program and get around this bug. But, no matter how I try to start from scratch, nothing I have been
able to try fixes the issue yet.
3. Re: BR error:not enough free storage code 25
pgauba Oct 18, 2010 2:38 AM (in response to h2ofun)This error message also comes, because of less hard disk space.
If you burn ISO for 35 GB project then you need double Hard disk space(more than 70 GB in this case) to burn iso.
Please check your hard disk space.
Pankaj Gauba
4. Re: BR error:not enough free storage code 25
h2ofun Oct 19, 2010 3:52 PM (in response to pgauba)My OS disc is 300 gig, only 150gig is being used.
My data disc is 1TB, only half of this being used.
I just have had a second project with the same setup, but different data, do the same thing. BR dies saying not enough space, but when I make a DVD from the project, works fine.
I am making these to image iso files on the disc.
5. Re: BR error:not enough free storage code 25
h2ofun Oct 21, 2010 5:54 AM (in response to h2ofun)I now have my 4th project where I am getting this error for the BR ISO build, but the DVD builds fine.
So, my file is a single mpg. Is there an issue at times when EN cannot figure out the disc layer break correctly?
Great if this is an issue. So, how would one fix this if this is the issue?
6. Re: BR error:not enough free storage code 25
DaveM888 Nov 29, 2010 4:34 PM (in response to h2ofun)See the following thread. This solution worked for me. See last post.
