XML Transformation Encoding
Jun 01, 2006 Jun 01, 2006
Hello, when i do transformation of xml to html and if i have french characters i receive in the html garbage characters instead i tried all encoding starting with utf-8 .... but the problem persist.
this is my xml
<MyDoc>
<TagTR index="PK">
<TagTD libelle="Emballage">Emballage Intermédiaire</TagTD>
</TagTR>
</MyDoc>
this is part of my my xsl
<?xml version="1.0" encoding="utf-8"?>
<xsl:stylesheet
version="2.0"
xmlns:xsl=" http://www.w3.org/1999/XSL/Transform"
xmlns=" http://www.w3.org/TR/REC-html40"
xml:lang="fr">
<xsl utput method="html" version="1.0" encoding="utf-8"/>
<xsl:template match="MyDoc">
<xsl:for-each select="TagTR">
<tr>
<td><xsl:value-of select="TagTD[@libelle='Emballage']" /></td>
</tr>
</tr>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
this is the output iam receiving
any help please
Advanced techniques
399
LEGEND , Jun 02, 2006 Jun 02, 2006
credev wrote:
> well infact thats my xsl
not to nit pick but that's not the same code & you did say it was "part". in any
case that xsl works. i output unicode hindi, arabic, thai, japanese, etc. ok. so
it's not cf, your xml or xsl. see: http://www.sustainablegis.com/unicode/xml/
using this code:
<cfprocessingdirective pageencoding="utf-8">
<cfquery name="getU" datasource="#dsn#">
SELECT uniText
FROM unicodeTest
ORDER BY uniLanguage
</cfquery>
<cfset xslFile=getDi...
> this is my xml
> <MyDoc>
> <TagTR index="PK">
> <TagTD libelle="Emballage">Emballage Interm?diaire</TagTD>
> </TagTR>
> </MyDoc>
and what's the xml doc's original encoding? what ver of cf? are you "touching"
the xml doc using cffile, etc.?
my xml is <?xml version="1.0" encoding="utf-8"?><MyDoc/> created with cfxml
the thing is that iam creating an xmlDoc loaded in memory ( by retreviving data from DB) then aim transforming this xmlDoc to html usingthe above xsl.
iam not beeing able to figure out whats going wrong.
Enthusiast ,
now that i see this stuff in the forums, it really looks like a simple encoding issue. but your xsl isn't complete enough for me to test to see where the issue actually lies.
<xsl:stylesheet
version="2.0"
xml:lang="fr">
<tr class="Arial_2_noir" height="10" align="left" valign="top" bgcolor="#CCCCCC">
</tr>
</xsl:for-each>
</xsl:template>
</xsl:stylesheet>
and the xml doc is
<?xml version="1.0"?>
<MyDoc>
<TagTR>
</TagTR>
</MyDoc>
using this code:
SELECT uniText
FROM unicodeTest
</cfquery>
<cfset xslFile=getDirectoryFromPath(GetCurrentTemplatePath())&"test.xsl">
<cffile action="read" file="#xslFile#" variable="xslDoc" charset="utf-8">
<cfxml variable="MyDoc">
<MyDoc>
<cfoutput query="getU">
<TagTR index="PK">
<TagTD libelle="Emballage">#uniText#</TagTD>
</TagTR>
</cfoutput>
</MyDoc>
</cfxml>
<cfset transformedXML = XmlTransform(mydoc, xslDoc)>
<table><cfoutput>#transformedXML#</cfoutput></table>
btw i don't like what the transform did to the vietnamese (last row in the table).
what ver of cf? if you dump the data out of the database via cf using utf-8
encoding, does it work? what encoding turns up in your browser when you run your
cf page?
Well i should say thank you alot... you just fixed my problem
i added <cfprocessingdirective pageencoding="utf-8"> to the top page where iam loading my xml and it worked!
thank you
Documentation
