SOLVED
button that increments and one that clears
Avatar
Level 1
Hello, could anyone help me with a code for a button when clicked,  incremements by 1. I have a numeric field (not sure if it should be a  numeric or text field), and a button. I want when the user clicks the  button, the number in either the text or numeric field increments by 1. I  also need a code for another button, that when clicked, clears the text  field. I appreciate your help.
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
To increment....
// form1.page1.subform1.incBtn::click - (JavaScript, client)
form1.page1.subform1.nf.rawValue = form1.page1.subform1.nf.rawValue + 1;
if (form1.page1.subform1.tf.isNull) {
  form1.page1.subform1.tf.rawValue = "0";
var numStr = form1.page1.subform1.tf.rawValue;
form1.page1.subform1.tf.rawValue = parseInt(numStr) + 1;
To clear....
// form1.page1.subform1.clearBtn::click - (JavaScript, client)
form1.page1.subform1.nf.rawValue = null;
form1.page1.subform1.tf.rawValue = null;
Avatar
Correct answer by
To increment....
To clear....
Avatar
Level 1
Wow, that works awesome. Thanks for such a rapid response.
Avatar
Level 1
Thanks for the response, can a "clear" button be used to clear all the  fields to include a calendar and dropdown list? basically push one  button and all the fields become blank. I guess I could add each field  in the .rawValue=null, but there are too many to do that. I tried using  xfa.event.reset() but that did not work
Avatar
Level 1
Avatar
There is an object in the standard library called 'Reset Button'. It clears all form fields by issuing xfa.host.resetData().
Steve
Avatar
Level 1
Steve you always come through, thanks for always being so helpful.
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
