I have created a skin for my main app...Now when I try to work on it in design mode FB gives warnings and will not display the application in Design mode until I remove the skin.
Can you please give the following details :
which version of flash builder ?
Is the issue reproducible on a fresh project ? If not , please share your project
what is the warning observed ?
Ok created a sample application does the same thing...
Am trying to create an application with a status bar using adobe air 2.0, windows 7, and Flash Builder 4.01
Wasn't sure how to get to the variables in the skin in the skin I hacked using flex globals to get to some variables in the main app...
But if you try this in design mode you will see that the application does not view correctly in design mode of the mian TestAppSkin.mxml file...
I have a much more complicated application and none of my app shows up in design mode if I have this skinclass set in the main app file...
Thanks for your help...
Here is the generated then modified skin file tAppSkin.mxml
ADOBE SYSTEMS INCORPORATED
Copyright 2009 Adobe Systems Incorporated
All Rights Reserved.
NOTICE: Adobe permits you to use, modify, and distribute this file
in accordance with the terms of the license agreement accompanying it.
<!--- A skin class for the Spark WindowedApplication and Window containers.
This class defines just a border and status bar, but no gripper button,
title bar, or title bar buttons.
<p>You can either use system chrome, the FlexChromSkin class, or
the WindowedApplicationSkin class to define the appearance of
the WindowedApplication and Window containers.
To use the WindowedApplicationSkin class with the WindowedApplication container,
set <code>systemChrome</code> to "none"
in the application's .xml file, and set the <code>skinClass</code> style to
spark.skins.spark.WindowedApplicationSkin.
To use the WindowedApplicationSkin class with the Window container,
set the <code>Window.systemChrome</code> property to "none",
spark.skins.spark.WindowedApplicationSkin.</p>
@see spark.components.WindowedApplication
@langversion 3.0
@playerversion Flash 10
@playerversion AIR 1.5
@productversion Flex 4
<s:SparkSkin
xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:fb="
http://ns.adobe.com/flashbuilder/2009" alpha.disabledGroup="0.5" xmlns:mx="library://ns.adobe.com/flex/mx" width.normal="600" height.normal="480">
<fx:Metadata>[HostComponent("spark.components.WindowedApplication")]</fx:Metadata>
<fx:Script fb:purpose="styling">
/* Define the skin elements that should not be colorized.
* For WindowedApplication, border and status bar background are colorized,
* but the content area and status text are not.
* Exclude the titleBar and scroller because they are SparkSkins and we
* don't want to colorize them twice.
* @langversion 3.0
* @playerversion Flash 10
* @playerversion AIR 1.5
* @productversion Flex 4
static private const exclusions:Array = ["backgroundRect", "contentGroup", "statusText"];
* @private
override public function get colorizeExclusions():Array {return exclusions;}
* @private
override protected function initializationComplete():void
useChromeColor =
true;
super.initializationComplete();
mx.core.FlexGlobals.topLevelApplication.g_statusBarCopyProgress = progress_statusBarCopyProgress;
mx.core.FlexGlobals.topLevelApplication.g_statusBarPlayerProgress = progress_statusBarPlaylistPlaying;
mx.core.FlexGlobals.topLevelApplication.g_statusBarModeText = label_statusBarModeText;
mx.core.FlexGlobals.topLevelApplication.g_statusBarModeLabel = label_statusBarMode;
mx.core.FlexGlobals.topLevelApplication.g_statusbarCopyIdleLabel = label_statusBarCopyIdle;
mx.core.FlexGlobals.topLevelApplication.g_statusBarPlayerIdleLabel = label_statusBarPlayerIdle;
* @private
override protected function updateDisplayList(unscaledWidth:Number, unscaledHeight:Number) : void
backgroundFill.color = getStyle(
"backgroundColor");
backgroundFill.alpha = getStyle(
"backgroundAlpha");
super.updateDisplayList(unscaledWidth, unscaledHeight);
</fx:Script>
<s:states>
<s:State name="normal" />
<s:State name="disabled" stateGroups="disabledGroup" />
<s:State name="normalAndInactive" stateGroups="inactiveGroup" />
<s:State name="disabledAndInactive" stateGroups="disabledGroup, inactiveGroup" />
</s:states>
<!-- layer 1: background fill -->
<!--- Defines the background color of the skin. -->
<s:Rect id="backgroundRect" left="0" right="0" top="0" bottom="0" >
<s:fill>
<!--- @private -->
<s:SolidColor id="backgroundFill" />
</s:fill>
</s:Rect>
<!-- layer 2: content + status bar -->
<s:Group left="0" right="0" top="0" bottom="0" minHeight="24" minWidth="0" >
<s:layout>
<s:VerticalLayout gap="0"/>
</s:layout>
<!-- content -->
<!--- @copy spark.components.SkinnableContainer#contentGroup -->
<s:Group id="contentGroup" width="100%" height="100%" minHeight="0" minWidth="0"/>
<!-- status bar -->
<!--- @copy spark.components.WindowedApplication#statusBar -->
<s:Group id="statusBar" width="100%" minHeight="24" >
<!-- status bar fill -->
<s:Rect left="0" right="0" top="0" bottom="0">
<s:fill>
<s:LinearGradient rotation="90">
<s:GradientEntry color="0xE2E2E2" />
<s:GradientEntry color="0xD9D9D9" />
</s:LinearGradient>
</s:fill>
</s:Rect>
<!-- status bar highlight -->
<s:Rect left="1" right="1" top="1" bottom="0" >
<s:stroke>
<s:LinearGradientStroke rotation="90" weight="1">
<s:GradientEntry color="0xEAEAEA" />
<s:GradientEntry color="0xBEBEBE" />
</s:LinearGradientStroke>
</s:stroke>
</s:Rect>
<!-- status text -->
<!--- @copy spark.components.WindowedApplication#statusText -->
<s:Label id="statusText" top="2" bottom="2" left="10" right="10" verticalAlign="middle"
fontSize="
10" color="0x585858" width="100%" maxDisplayedLines="1" text.normal="Test App" fontSize.normal="14"/>
<s:Label includeIn="normal, disabled, disabledAndInactive, disabledGroup, inactiveGroup, normalAndInactive" y="3" text="Player Mode" fontSize="14" height="20" verticalAlign="middle" width="94" textAlign="right" id="label_statusBarModeText" right="302"/>
<s:Label includeIn="normal, disabled, disabledAndInactive, disabledGroup, inactiveGroup, normalAndInactive" y="3" text="Manual" fontSize="14" verticalAlign="middle" height="20" width="76" id="label_statusBarMode" itemCreationPolicy="immediate" right="221" textAlign="center"/>
<mx:VRule includeIn="normal, disabled, disabledAndInactive, disabledGroup, inactiveGroup, normalAndInactive" y="2" width="3" height="20" right="105"/>
<s:Label includeIn="normal, disabled, disabledAndInactive, disabledGroup, inactiveGroup, normalAndInactive" y="3" text="Player is Idle" width="94" height="20" id="label_statusBarPlayerIdle" fontSize="14" verticalAlign="middle" toolTip="No playlist is playing" itemCreationPolicy="immediate" right="109" textAlign="center"/>
<mx:ProgressBar includeIn="normal, disabled, disabledAndInactive, disabledGroup, inactiveGroup, normalAndInactive" y="3" label="Playing" indeterminate="true" width="94" labelPlacement="right" fontSize="14" itemCreationPolicy="immediate" id="progress_statusBarPlaylistPlaying" toolTip="Playlist is playing" right="109" visible="false"/>
<mx:VRule includeIn="normal, disabled, disabledAndInactive, disabledGroup, inactiveGroup, normalAndInactive" y="3" width="3" height="20" right="213"/>
<mx:ProgressBar includeIn="normal, disabled, disabledAndInactive, disabledGroup, inactiveGroup, normalAndInactive" y="3" labelPlacement="right" label="Copying" indeterminate="true" width="94" fontSize="14" id="progress_statusBarCopyProgress" click="progress_statusBarCopyProgress_clickHandler(event)" itemCreationPolicy="immediate" right="3" visible="false"/>
<s:Label includeIn="normal, disabled, disabledAndInactive, disabledGroup, inactiveGroup, normalAndInactive" y="3" text="Copy is Idle" width="94" height="20" fontSize="14" verticalAlign="middle" right="5" id="label_statusBarCopyIdle" itemCreationPolicy="immediate" toolTip="No copy is in progress" textAlign="center"/>
<fx:Script>
<![CDATA[
import mx.controls.Alert;
import mx.core.FlexGlobals;
protected function progress_statusBarCopyProgress_clickHandler(event:MouseEvent):void
mx.core.FlexGlobals.topLevelApplication.g_dlgProgress.visible =
true;
</fx:Script>
</s:Group>
</s:Group>
</s:SparkSkin>
And Here is the main app file TestAppSkin.mxml:
<?xml version="1.0" encoding="utf-8"?>
<s:WindowedApplication
xmlns:s="
xmlns:mx="
skinClass="
tAppSkin">
<fx:Script>
<![CDATA[
import flash.text.*;
import mx.collections.*;
import mx.controls.ProgressBar;
import mx.utils.*;
import spark.components.Label;
import spark.components.WindowedApplication;
// Status bar objects
public var g_statusBarCopyProgress:ProgressBar;
public var g_statusBarPlayerProgress:ProgressBar;
public var g_statusBarModeText:spark.components.Label;
public var g_statusBarModeLabel:spark.components.Label;
public var g_statusbarCopyIdleLabel:spark.components.Label;
public var g_statusBarPlayerIdleLabel:spark.components.Label;
</fx:Script>
<fx:Declarations>
<!-- Place non-visual elements (e.g., services, value objects) here -->
</fx:Declarations>
</s:WindowedApplication>
Hi
Can you please log a bug in adobe bug base http://bugs.adobe.com/jira/secure/Dashboard.jspa along with the sample files as well as the detailed steps to reproduce this issue ? We will definitely look into this.
Regards
Shanaz
Here is a work around, remove the skin from the
area and put it in the fx:Style area ie:
<fx:Style>
@namespace "library://ns.adobe.com/flex/spark";
WindowedApplication {
skinClass:ClassReference("skins.MainAppSkin");
This way you can still see and work on your main application in design mode...
