Hello there!
Using LiveCycle Designer and Reader Extensions, is there a way to insert the date and time when a document has been created?
What must I use, JavaScript?
Thank you for any hints.
Marcos
Solved! Go to Solution.
Total Likes
You could add code to the prePrint event that woudl enter the current Date and time into a field onto the form. This date and time woudl be taken from the local system. There is a Current Date object in the Custom library. Use that but take the code that is in the Layout Ready event and move it to the PrePrint event.
paul
Total Likes
Do you mean when the document is opened by the user or when the Reader Extensions are applied?
paul
Total Likes
Actually I need the PDF to have a date of when it was printed.
Thank you.
Marcos
Total Likes
paul
Total Likes
