Hi all,
I’m new with Flex 4, and learning
How to convert a formatted string to a number
example “$54,500.95″ to “54500.95″ in order to do same calculation
any help will be appreciated.
This might be the solution in case of currency formatter (you can write a utility class and use it)
<code>
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
<fx:Script>
<![CDATA[
protected function test_clickHandler(event:MouseEvent):void
var value1:String = currency.format(a);
var value2:String = currency.format(b);
var num1:String = value1.substr(1,value1.length);
for(var i:int=0; i<num1.length; i++)
num1 = num1.replace(",","");
var num2:String = value2.substr(1,value2.length);
for(var j:int=0; j<num2.length; j++)
num2 = num2.replace(",","");
var total:Number = Number(num1) + Number(num2);
formatNumber.text = String(total);
</fx:Script>
<fx:Declarations>
<fx:String id="a">5400000000000.56</fx:String>
<fx:String id="b">550000000000.66</fx:String>
<mx:CurrencyFormatter id="currency" precision="2"/>
</fx:Declarations>
<s:layout>
<s:VerticalLayout/>
</s:layout>
<s:Label text="{currency.format(a)}"/>
<s:Label text="{currency.format(b)}"/>
<s:Label id="formatNumber"/>
<s:Button id="test" label="Convert" click="test_clickHandler(event)"/>
</s:Application>
</code>
Thank you paleti.suresh it works beautiful
