1 Reply Latest reply on Jun 2, 2006 11:25 AM by Newsgroup_User
    Classes may only be defined in external ActionScript 2.0 class scripts
    m.dugan Level 1
      Ok I'm getting this when I try and publish my FLVPlayer:
      **Error** C:\Documents and Settings\mdugan\My Documents\FLVPlayer\FLVPlayerTester.as: Line 14: Classes may only be defined in external ActionScript 2.0 class scripts.
      class FLVPlayer extends MovieClip
      Total ActionScript Errors: 1 Reported Errors: 1
      The problem is, my class IS defined in an external ActionScript 2.0 class script. So I don't know why this error is coming up, check the code. Anyone help would be greatly appreciated.
        • 1. Re: Classes may only be defined in external ActionScript 2.0 class scripts
          Level 7
          m.dugan,
          Checking ...
          Aha. Well, in your class itself, you've written this:
          class FLVPlayer extends MovieClip { // etc.
          ... but your file name appears to be FLVPlayerTester (visible in the error
          message). So the compiler is looking for a file named FLVPlayer and doesn't
          find one; hence, classes may only be defined in external scripts.
          Change the name of your file, or change the name of the class.
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
