1 2 3 Previous Next 91 Replies Latest reply: Feb 1, 2012 8:12 AM by rogersphoto.com Go to original post RSS
      • 40. Re: No MPEG preview or playback in Bridge CS5
        Ann Bens CommunityMVP
        I whish it did the same for mpeg.
        • 41. Re: No MPEG preview or playback in Bridge CS5
          tlt1068 Community Member
          Ann,
          Check inBridge, go to menu
          Edit > Preferences (or Crtl K for Wins), go to the File Type Associations (on left pan) and check what MPEG Media (.mpeg, .mpg) is associated to on the right pan.
          If it's None, then
               you might want to associate it with a player of your choice (or whatever is installed).
          Else if
               you might want to associate it with a different player of your choice (or whatever is installed).
          Else If
                  It might be worth associating the following with the same player:
          MP3 Audio (.mp3)
          MPEG Audio (.aac, .mp2)
          MPEG Audio Stream (.mpa)
          MPEG-4 Audio Layer (.m4a)
          Either WMP or QuicKTime or even IE8 (believe it or not) can do...
          Hope it helps..
          • 42. Re: No MPEG preview or playback in Bridge CS5
            Tried them all: nope.
            • 43. Re: No MPEG preview or playback in Bridge CS5
              If it plays by the player of your choice, then your issue is definitely within Bridge.  Even if you didn't associate all the MPEGs (i.e. none), Bridge has auto-detect to pull in the required dll for previewing.  Chances of Bridge failing this is very low.  Chances of your "cache" in disorderly state is, and I am sad to say, rather high.  That's quite normal by the way !  I personally flush out the cache once a week.  I do this in 2 ways:
              (1)  Within the folder of content, right click on the file(s) - doesn't matter if one or a million files selected - and select [Purge Cache for Selection]
              (2)  In Preference > Cache hit [Compact Cache] | [Purge Cache].  This basically does it at a more global level...
              After (1) & (2), if the issue is still there, then either Bridge or the player of your choice has a registry problem (assuming for pc here).  Now Windows registry is not as friendly as Bridge, so don't go there!  Re-installing the Adobe product is useless here cos you'll get the same issue again for sure.  I'd personally format the entire box and re-install Windows from scratch.  But that's me and I wouldn't recommend this approach to anyone...!
              • 44. Re: No MPEG preview or playback in Bridge CS5
                Thanks for trying to help me out; tried that also the purge cashe.
                You might be right: a clean install.
                Thanks again.
                • 45. Re: No MPEG preview or playback in Bridge CS5
                  rickg1949 Community Member
                  Well, tlt, I have purged many times, both from within Bridge and externally.  I also did do a "clean install of CS 5 to a machine with a "clean install" to Windows 7 64 bit.  That's what frosts me: everything else is working amazingly well.  Only this one glitch.
                  In my main workstation (Vista 64 bit), I did a "clean install" to CS 5 and go the same, "no mpeg preview" results until I did that ffdshow codec install which I hated to do.  Any now it does seem as mentioned above that my Premiere playback has suffered a bit.
                  Doing a total "clean install/format the C: drive" is not an option.  Don't have the 2-3 days that that would take to get back up to speed.
                  Going to take a look at that file acciation list thing above and make sure all those various file types point to same player.  Will let you all know.
                  Rick
                  • 46. Re: No MPEG preview or playback in Bridge CS5
                    Rick,
                    Here's what puzzle me:
                    If your WMP can play your HD mpeg  file, why should you need to install other codec?
                    It also means that WMP is able to locate (or associate if you like) the correct dll (or codec or whatever engine you want to call) to play your file.
                    See what I am getting at?  I could be wrong, but I think your Bridge has either two issues:
                    (1)  It has sourced (I'm a unix boy so excuse that term) the correct dll, but unable to preview (which really is just passing your mpeg file to the source) because the cached version (not your original mpeg file) is in limbo state.  When you purge, you flush out the old and regenerate a new version of the mpeg file in the Bridge's cache.
                    (2)  Your Bridge is confused and doesn't know which is the correct dll to source.  This is when you go in and tell Bridge which dll to use (the associate thing...).
                    BTW, what is the size of your mpeg file?  Is there a file size limitation for Bridge to preview?  Might be worth getting an Adobe expert to confirm this...
                    Also have you play around with the Cache Size (between 10,000 to 500,000) in Preference > Cache?
                    How old is your camera?  Silly question but is the file that comes out of your camera compatible with 64-BIT OS?  WMP can play it because it has a huge library to look things up ... Bridge on the other hand, doesn't know about this huge library.
                    Sorry I'm running out of idea... honestly I rarely have anything to do with mpeg files.  I'm a still boy who have recently caught onto DSLR video and hence stumbled accross your issue, but with .mov files...
                    • 47. Re: No MPEG preview or playback in Bridge CS5
                      Appreciate your feedback.  I have done all kinds of "flushing" including deleting files/folders under /cache with no success.  I am wondering if it may be something to do with Windows Media Player 12 and its interface with Bridge?  Thinking this, since I re-installed CS 4 and under that version Bridge won't preview HDV files for me either.
                      File sizes not an issue, short clips 10-15 seconds. and only trying to put 3 clips in cache folder.  Odd thing on Win 7 machine is that in Bridge, double-clicking on a .mpeg (HDV) clip does NOT open WinMediaPlayer while  double-clicking .m2v clip does.  And YES, I have associated both/all mpeg file types to play with WinMediaPlayer.exe ver 12.  Those same files will open and play with WinMediaPlayer when double-clicked in WinExplorer, so why not from Bridge?  I don't want to load/add a codec pack to this workstation, like I had to do in my main edit station.  And I'd love to get rid of them on that machine.
                      Here's a screenshot of the list of mpeg codecs that show up under Windows Media Player.  Anyone see anything strange/missing?
                      Funny thing is, I had great results with CS, CS 3, CS 4.  Sure stability was a bit shakey in earilier versions, but in CS 4 everything worked perfectly.  So with a clean install on machine with clean install of Windows 7 I expected the same results.
                      Good luck with the DSLR, that's a real creative tool to be using.
                      • 48. Re: No MPEG preview or playback in Bridge CS5
                        TTweite
                        The way I read that error message, Bridge, for some reason, couldn't find Windows Media Player in it's default location. I copied the whole wmp folder and pasted it on my D: (Storage) drive. I went into Bridge preferences and pointed to this copy of the player. After a reboot, everything is as it should be. That CODEC Pack was not necessary. I agree with the previous post that advises avoiding adding any CODEC Packs if you don't absolutely have to. Before I hit on this solution, I also cleared the cache and reset Bridge preferences to default (hold down ctrl + alt while starting Bridge.) I realize that it's been a while since anyone posted to this thread, but I thought that my experience may be of use to someone experiencing this problem.
                        • 49. Re: No MPEG preview or playback in Bridge CS5
                          TT,
                          Thanks for your news.  I still can't get mpeg playback inside Bridge for HDV .mpeg clips which were captured in either Premiere CS4 or CS5 on my Win7 laptop workstation.  Did the 3rd party CODEC thing on my main workstation (Vista64bit) and got clips to play in Bridge but I am nervous.  Today when logging and loading in Premiere I had no video on the desktop for the first time ever.
                          Used monitor to view clips and they loaded but each one produced an error message saying that  "The file is busy, and unable to be updated."  That seems to be new and the saving and process seemed to be about 4 times longer after each clip was captured.
                          Anyone have any thoughts?  Would love to purge those 3rd party CODECs.
                          rg
                          • 50. Re: No MPEG preview or playback in Bridge CS5
                            Todd_Kopriva Adobe Employee
                            In a recent thread on the Premiere Pro user-to-user forum, a user's problem was traced back to an installation of K-Lite, and it was indicated that installation of K-Lite was recommended on this thread.
                            So, here I am to make this clear:
                            The K-Lite codec pack severely impairs the functioning of many video applications, including Premiere Pro, After Effects, and Adobe Media Encoder.
                            Note the warning on the K-Lite download here:
                            http://www.videohelp.com/tools/sections/codec-packs
                            "Warning! If you install all the included codecs/decoders you might get problem with other video software on your computer."
                            Heed that warning.
                            • 51. Re: No MPEG preview or playback in Bridge CS5
                              TTweite Community Member
                              The problem I was having was with .m2ts files which is a Sony AVCHD wrapper for HD mpeg files. I would double click on the thumbnail in Bridge and get the same error message you reported. If I go into Bridge preferences and point to the Windows Media Player in it's default location, I get the same error. But, if I point to the copy of media player that I moved to a new location, a media player window pops up and plays the file. I have no clue as to why this worked for me, but it did. Navigate to C:\Users\Your user name\AppData\Roaming\Adobe\Bridge CS5 and find a file named Adobe Bridge Opener Preferences.xml. Open it in Notepad and look for a line that looks something like this:
                              <item description="$$
                              $/Bridge/OpenersXML/Description/MPEGMedia=MPEG Media" extensions="mpeg mpg m2ts" app_name="OS" app_path="D:\Windows Media Player\wmplayer.exe">. (They're in alphabetical order by description.) The app_path here is the location where I placed an exact copy of the Windows Media Player folder that is located in C:\Program Files (x86). The m2ts, I added myself.
                              As far as the CODEC Pack goes, I assume that there's no entry in Control Panel->Programs and Features (Win7) or Add/Remove Programs on earlier releases. If that's the case, you'll need to restore from a backup that's as close as possible to right before you installed the pack. Make sure you backup any files that you want to keep that you've produced or saved since then. If no backup is available, you may need to reinstall the system and CS5.
                              • 52. Re: No MPEG preview or playback in Bridge CS5
                                Jon-M-Spear Community Member
                                Hi Todd.
                                Warning heeded.  I removed K-lite some time ago as I was unhappy with 3rd party codecs...
                                But rather than telling us what we shouldn't do, does Adobe have any advice on what we should do?  I remain unable to preview mpeg files (Z1 HDV) in Bridge on both my main editing PC and my laptop.
                                • 53. Re: No MPEG preview or playback in Bridge CS5
                                  I found this thread at Major Geeks that may be helpful http://forums.majorgeeks.com/showthread.php?t=148496
                                  • 54. Re: No MPEG preview or playback in Bridge CS5
                                    Same here, no HDV preview in CS5,  worked like a charm
                                    in CS3 and CS4, plug n played.
                                    rg
                                    • 55. Re: No MPEG preview or playback in Bridge CS5
                                      Well, I have totally clean system now after 18 hours of cleansing.  Problem is I'm back to square one with the "no MPEG previewing in either Bridge or even Windows Media Player.  Premiere seems back to normal, all video (HDV) displayed while logging.
                                      Can anyone from Adobe HQ offer any help on getting HDV footage, captured using Premiere to play in Bridge??????  Please??
                                      Come on, this is amazing to have to put up with after my annual $1,000 pledge to the Adobe Mother Church.  I am such an advocate of the product line but this is like driving the Indy 500 with a front wheel locked up.
                                      (also posted in Premiere Forum.)
                                      Thanks to Adobe in advance.  rg
                                      • 56. Re: No MPEG preview or playback in Bridge CS5
                                        Have you checked your file associations settings for mpeg files? In Windows 7, go to Control Panel->Programs->Default Programs->Set Associations. I don't have a Vista machine handy, but it shouldn't be too hard to find. Scroll down to the file extension you're having a problem with and make sure current default is set to Windows Media Player. Aside from that, I'm pretty much out of suggestions.
                                        • 57. Re: No MPEG preview or playback in Bridge CS5
                                          Nope TTweite, no amount of associating files in either Windows 7 or Bridge will make Mpegs play in the preview panel.
                                          Both my laptop and my main PC have had Windows 7 and Adobe Production Bundle CS5 reinstalled at least one, so whatever is causing the problem is neither random nor inconsistent.
                                          Come on Adobe!
                                          • 58. Re: No MPEG preview or playback in Bridge CS5
                                            adobe2418 Community Member
                                            This is a novice question to you but "why do you need  to play video files
                                            in Bridge"?
                                            • 59. Re: No MPEG preview or playback in Bridge CS5
                                              Adobe2418,
                                                To me, Bridge is my media manager tool and a wonderful part of my workflow.  I have several TB's of stock video, still, and graphics that I work with over and over again for various clients.  Bridge allows me to go into a RAID and find "that old shot we used on such-and-such a spot" and bring it into a new project quickly.  I worked that way in CS3 and CS4 for years and clients loved it.  AVID has that kind of clip preview function in there basic system if I remember right.  Being a visual person, it's so quick to "paint" a new video by looking at clips then trying to remember names.  Making Bridge play its role to me is why I've loved having "suite" software.
                                              Still a devoted user (albeit: tested),
                                              Rick
                                              • 60. Re: No MPEG preview or playback in Bridge CS5
                                                Rick,
                                                Thanks for your explanation. My video projects and still work are pretty
                                                much separate entities; your work seems to be more multimedia.
                                                Very interesting. I hope you get the issue resolved.
                                                CC
                                                • 61. Re: No MPEG preview or playback in Bridge CS5
                                                  While trying to solve my problem I noticed that Windows Media Player does not have MainConcept (Adobe2) listed as one of the installed video codecs.  That always was included in CS3 and 4 wan't it?  I see it as an encoding option using AME but not on the list for Win Media Player in either my Win7 laptop or Vista64bit edit station.
                                                  I have to think that the disconnect between Win Media Player and CS5 Bridge is where my problem lies.  How can WE patch it????
                                                  rg
                                                  • 62. Re: No MPEG preview or playback in Bridge CS5
                                                    FWIW, I'm currently trying to find a resolution to this issue. My normal job is technical support for Premiere Pro, After Effects, and Adobe Media Encoder, but I thought that I should try to help out on this Bridge issue---if only because it may keep more people from installing damaging third-party codec packs that make my life h*** when trying to support those video applications.
                                                    • 63. Re: No MPEG preview or playback in Bridge CS5
                                                      Thanks, Todd!
                                                      I'm subscribed to this thread and will be interested to see how it turns out.
                                                      • 64. Re: No MPEG preview or playback in Bridge CS5
                                                        Xiaofeng Zhao Adobe Employee
                                                        Bridge Dev is investigating on this issue. We will try to find out a possible workaround so that it will not break your workflow.
                                                        - Xiaofeng
                                                        • 65. Re: No MPEG preview or playback in Bridge CS5
                                                          This is good news, this has been a pita for me ever since CS4, although it did work at the beginning.
                                                          The Bridge is also part of my workflow.
                                                          As a workaround i use Cineform avi's which play just fine.
                                                          • 66. Re: No MPEG preview or playback in Bridge CS5
                                                            I wonder if I am still the only one who misses this feature in Bridge?  I spent a couple hours on the phone with Adobe Tech support with no positive results.
                                                            Today, Apple issued a Quicktime update, I got all excited, installed it (maybe the missing 64bit CODEC was an early holiday present), but no playback of HDV files in Quicktime or Bridge on the Win7 machine!
                                                            Am I alone?  I have a break in editing for a few days so I might uninstall/reinstall Master Suite yet one more time.  And do the same for Quicktime (the only suggestion made by Adobe Tech support.
                                                            If I knew Marty McFly I'd have him drive me back to my days in CS4 and stay there.  rg
                                                            • 67. Re: No MPEG preview or playback in Bridge CS5
                                                              sittinghair Community Member
                                                              I am also having this problem. Clean install on brand new PC.
                                                              Windows 7 Ultimate - 64bit
                                                              The .mpg thumbnails display correctly in the 'Content' panel. However the 'Preview' panel simply displays the MPEG icon and preview is not available.
                                                              Double clicking the thumbnail in 'Content' correctly opens the selected .mpg in my video player... So looks like that is how I will be previewing my videos.
                                                              I have tried the File Association > Cache Purge tip mentioned earlier... no difference.
                                                              Extremely frustrating as 90% of all my video files are in .mpg format.
                                                              • 68. Re: No MPEG preview or playback in Bridge CS5
        It clearly is a bug and, as of last month, it looks as though Adobe has finally recognised the issue.  Thanks, Todd.  Let's hope to see the fruits of your labour soon!
        • 69. Re: No MPEG preview or playback in Bridge CS5
        J-MS,
        Hope you're right!  I have been corresponding with the Adobe Support Portal.  They have had me try the same solutions over again without any success.  Even asked me to run the "Content Disk" in the installation package but the only thing on that disk are the PDF's in every language, no CODECs or player programs of course.
        Misery loves company, sorry you guys are in the same boat and just hope we find a solution soon without going outside the Adobe box (that was not a good experience.)  rg
        • 70. Re: No MPEG preview or playback in Bridge CS5
        Please email me the case number for this conversation (to kopriva -at- adobe -dot- com).
        The support agents shouldn't be sending you around in circles like this.
        Here's what's going on:
        Previous versions of After Effects and Premiere Pro installed both DLLs and ActiveX controls for codecs licensed from a third party. After Effects CS5 and Premiere Pro CS5 only install the DLLs, because we don't need the ActiveX controls, and they were just causing problems. Unknown to us, Bridge was relying on those ActiveX controls being installed. So, Bridge CS5---not having these codecs---can't play some kinds of files.
        Windows 7 installs some of the required codecs as part of the operating system; Windows Vista doesn't. That's why you're seeing different behavior between Vista and Windows 7.
        The long-term solution would be to have Bridge install its own codecs.
        • 71. Re: No MPEG preview or playback in Bridge CS5
        Thanks for the clarification Todd.
        However, I have Win 7 64 installed, and I am unable to
        view MPEGs in Bridge.  Which version of Win 7 installs the codecs that Bridge requires?
        • 72. Re: No MPEG preview or playback in Bridge CS5
        I said "some of". Some things work; some don't. I'm not certain of what codecs Windows 7 installs that Bridge is using.
        My detailed and certain knowledge ends at After Effects and Premiere Pro. I'm just sticking my nose into this Bridge stuff far enough to make sure that people stop installing damaging freeware codecs packs that make After Effects and Premiere Pro stop working.
        • 73. Re: No MPEG preview or playback in Bridge CS5
        Can you tell us which ActiveX controls might solve the problem? I still run CS4 on my laptop because it's a 32-bit machine. If I knew which files I need, it would be simple enough to copy and paste them into the CS5 install on my production machine.
        • 74. Re: No MPEG preview or playback in Bridge CS5
        Tee hee.  I thought you'd opened up a can of worms when you mentioned what you did, Todd!
        • 75. Re: No MPEG preview or playback in Bridge CS5
        The codecs are licensed for use by specific products, so I won't be telling you how to copy them over for use by other products.
        • 76. Re: No MPEG preview or playback in Bridge CS5
        DreamCaptureMedia Community Member
        Man I had really hoped that this last update would fix the mpeg playback problem..........
        • 77. Re: No MPEG preview or playback in Bridge CS5
        My heart skipped a beat too.  It was the first thing I tried after installing.  D-oh!
        • 78. Re: No MPEG preview or playback in Bridge CS5
        ouuuh, yes!!!  Thought I might have an early gift from the elves at Adobe-North-Pole, but my update stocking turned up empty.
        They have escalated my support case upstairs, so maybe, just maybe.....
        rg
        • 79. Re: No MPEG preview or playback in Bridge CS5
        Br QE Adobe Employee
        The latest Bridge patch 4.0.4 provides preview function to MPEG2-PS format files.  Due to system limitation, currently Bridge can not playback MPEG2-TS files.
        Bridge QE
