Show 5 replies
1. Re: Unable to change brush size
MTSTUNER Oct 8, 2010 1:26 PM (in response to Deep Woods)Check to make sure your caps lock is not on.
MTSTUNER
2. Re: Unable to change brush size
Deep Woods Oct 10, 2010 7:08 PM (in response to MTSTUNER)Bingo - That did it.
Thank you,
DW
3. Re: Unable to change brush size
ukgaurav Oct 26, 2010 6:16 AM (in response to Deep Woods)Also there is a shortcut for changing the brush size. It is [ and ]. You can check short cuts for PSE here.http://help.adobe.com/en_US/PhotoshopElements/7.0_Win/WSae2ea3b149d0c3591309e871039f8bc68a -8000.html
-Garry
4. Re: Unable to change brush size
Deep Woods Oct 26, 2010 7:44 AM (in response to ukgaurav)Thanks for your consideration Garry - I'm aware of the shortcut, but the problem happened to be having the caps lock on. When you are typing in caps even this shortcut doesn't work.
DW
5. Re: Unable to change brush size
ukgaurav Oct 26, 2010 7:52 AM (in response to Deep Woods)Ok, Thanks for the info.
