"View Selected Item" does not display
Jul 28, 2008 Jul 28, 2008
I'm using RoboHelp7 out of the Technical Communication Suite.
When I'm working on a topic and select the View Selected Item button, the topic does not display. When I first tried yesterday, nothing happened (IE didn't open and there was nothing in my tray). I contacted Oversea's support and was informed that there wasn't an incident for this occurance. I was instructed to uninstall and reinstall RoboHelp.
I uninstalled and reinstalled the applications and the button still doesn't work; however, this time there is an hourglass for an instant before not producing any results.
The button doesn't work with anything that I've created or with the example projects (Clownfish School). Any help would be greatly appreciated. I'd hate to have to regenerate the project just to look at a quick change.
Matt
699
Welcome to the forum.
Dual monitors in use here?
If so, see Snippet 61 on my site
Peter:
Thanks for welcoming me to the form and providing a solution. I used Rick's method in Snippet 61 and the preview appears.
Matt
I'm puzzled why you did it that way. The article starts with a very simple method that does not involve touching the registry but you are the second person to use Rick's earlier method recently. Rick's own view is the first method in the article is easier so what made you use the more complex method?
I really only leave it there in case the first method does not work for someone.
I used his method since the first one didn't work.
When I execuited the key commands and tried to move the window, only the main window moved -- not the preview. I tired a couple more times and them moved to the next solution.
After completing the Regeistry Edit commands, the preview window appeared.
Thanks.
May 11, 2010 May 11, 2010
Hi Peter
I know this is an old post now but I thought I'd let you know that I've just encoutered the same problem using RoboHelp 8 (as part of Tech Comms Suite 2) and I've had to go into the registry to fix it. The quick fix didn't work.
I may not be the only one who appreciates you keeping a record of all the different options for fixing problems!
Many thanks
Louise
Sounds like I need to add a note to that Snippet. Thanks.
@petergrainge
May 19, 2010 May 19, 2010
Just FYI, I tried the keystrokes on a standalone RH8 and they appear to work (although the Preview window wasn't really lost ). Maybe it's something to do with the Framemaker integration...
RoboHelp Documentation
Download Adobe RoboHelp
