I am having an issue with the code below. All three of the checkboxes work great together. But I am having an issue with some of the data that is being returned by the getResponses method in the third cfselect below. All of the display values being returned are showing correctly (ex. A,B,C,Good,Bad,Approved,Not Approved) in the drop down EXCEPT when the values are "Yes" and "No". For some reason "Yes" and "No" are being returned as "true" and "false" instead.
I have executed the getResponse method outside of the cfselect dumping the returned array and the values are displaying correctly as "Yes" and "No".
<cfselect name="category_cd"
bind="cfc:getCategories(category_cd='#form.category_cd#')"
style="width:300px;"
bindonload="true" /><br>
<cfselect name="question_cd"
bind="cfc:getQuestions(category_cd={category_cd},question_cd='#form.question_cd#')"
<cfselect name="response_id"
bind="cfc:getResponses(question_cd={question_cd},response_id='#form.response_id#')"
In the method I created, I have cast the value from the query, but it still returns as "true" and "false".
<cffunction...>
<cfquery name="qryResponses"...>
select response_id, CAST(response_txt as char(30)) as response_txt,response_sort_order_nbr,
CASE WHEN response_id = <cfqueryparam cfsqltype="cf_sql_varchar" value="#arguments.response_id#">
THEN 0
ELSE 2
END as Sort
from responses
where question_nm_cd = <cfqueryparam cfsqltype="cf_sql_varchar" value="#arguments.question_cd#">
</cfquery>
<cfloop query="qryResponses">
<cfset responseArray[qryResponses.currentrow][1]=qryResponses.response_id>
<cfset responseArray[qryResponses.currentrow][2]=qryResponses.response_txt>
</cfloop>
<cfreturn responseArray>
</cffunction>
Has anyone else experienced this issue with Yes/No values being converted to True/False?
Seems like the ajax is rendering it as boolean.
Quite possibly. You could try the space hack. Sometimes adding a space to the values is enough to prevent them from being treated as boolean. But check stackoverflow.com too. I know I have seen this question before, but cannot recall if there were more elegant solutions than the space hack ...
I've not experienced the problem, but if I was troubleshooting it, I'd start by dumping the query and the array in that cfc to see at what point the data started to differ from my expectations.
Dan,
Thank you for responding. The dump of the array show the correct values in Yes/No format. I believe something is happening to the data when it's bound to the cfselect. Seems like the ajax is rendering it as boolean. Is there a way I can force the type as a string? Ive tried toString and JavaCast on my array and nothing seems to work. Let me know if you know of something else to try. I'll post back if I figure it out.
Thank you, that did it. I will keep looking for a sexier fix, but for now this will do the trick. Much appreciated!
