Show 2 replies
1. Re: Any workaround for bad vertical display?
NotInUse Dec 18, 2008 4:16 PM (in response to NotInUse)Solved...
I had Acrobat set up to use the proper PPI of my 30" monitor (101ppi) setting it to 98ppi corrected the bad display. -
2. Re: Any workaround for bad vertical display?
GeorgeRudd Oct 27, 2010 8:55 PM (in response to NotInUse)Thanks, this has been driving me nuts for weeks. Every time I dragged a PDF to one of my vertically rotated monitors the aspect ratio got totally whacked out.
It seems like the solution is simply to not use the “System Default” resolution option. Any custom setting, even manually setting it to 93 pixels/inch (the exact same resolution as the System Default) corrects the distorted aspect ratio problem.
Adobe should fix this bug. It’s been around for several updates.
