CF Code in CFFile created pages?
Guest
Jun 04, 2006 Jun 04, 2006
I've hit a brick wall here, so would gladly appreciate some input!
I'm trying to automate, as much as possible, the creation of 'sub sites' under a domain. At the moment, the directory is created using CFDirectory and the static files (images, css docs etc) are copied into it. However, I need to be able to set the datasource specific to the sub-site - which I had planned to do within the application.cfm file.
I can get CFFile to create the application.cfm file, and put it in the right place, but the actual file itself is empty.
All I need the application.cfm file to contain is <cfset datasource="blah"> (for the time being at least, but once I solve this issue I'll be able to address anything else I need to add later).
Now, I have 2 problems here -
Firstly, I need the CFFile to actually write the code into the application.cfm file - at the moment it just executes, and therefore produces a blank page. Secondly, the 'blah' part I need to actually be executed, because the actual datasource name I want to write into the page will be determined by the page that is running the cffile (and getting the variable from a form the page before).
Hope that makes sense, but if anyone else can suggest a better method for doing this, I'm all ears!
Advanced techniques
371
Create the folder C:\CFusionMX7\wwwroot\clientSite\ and run
<cfset app_cfm_content = "<cfapplication name=""apptest""
clientManagement = ""yes""
setClientCookies = ""yes""
setDomainCookies = ""no""
loginStorage = ""session""
sessionManagement = ""yes""
sessionTimeout = ""#CreateTimeSpan(0,0,10,0)#""
applicationTimeout = ""#CreateTimeSpan(1,0,0,0)#"">
<cfset datasource = ""blah"">
<cferror type=""exception"" exception=""any"" template=""error_page.cfm"" mailto=""me@medomain.com"">">
<cffile action="WRITE" file="C:\CFusionMX7\wwwroot\clientSite\Application.cfm" output="#app_cfm_content#">
Guest
Jun 05, 2006 Jun 05, 2006
That worked a treat, thanks for your help - much appreciated!
Documentation
