1. Re: Copy and pasting keyframes from 1 graphic to another - PP won't let me
Colin Brougham Oct 28, 2010 6:18 PM (in response to David Zeno)Where are you trying to paste: in the Timeline Panel or in the Effects Control Panel? Pasting won't work (at least, not keyframes) directly into a sequence in the Timeline panel. However, you can paste into the ECP with or without the destination effect selected.
Yes/no?
2. Re: Copy and pasting keyframes from 1 graphic to another - PP won't let me
David Zeno Oct 28, 2010 6:43 PM (in response to Colin Brougham)Hi Colin
I'm trying to paste right into the ECP ( Effects control panel ) ( window )
So, I go to my graphic on the time line, click to select it. The keyframes appear in the ECP window. I then select them and copy to memory.
( right click and select "copy" )
Next I go to the graphic I wish to apply the key frames to......... click it on the time line to select it, then I go up to the ECP window, and right click in that window,
but................. the "paste" option is grayed out
don't know what to do :-(
Dave.
3. Re: Copy and pasting keyframes from 1 graphic to another - PP won't let me
shooternz Oct 28, 2010 6:47 PM (in response to David Zeno)Try this:
Copy the Opacity Header belonging to the clip.
Select the new clip and paste it.
or
Right Click it and save it as a Preset.
4. Re: Copy and pasting keyframes from 1 graphic to another - PP won't let me
Colin Brougham Oct 28, 2010 6:51 PM (in response to David Zeno)Are you able to paste the keyframes back to the same clip? Are you able to copy and paste a single keyframe to the second clip? If that works, try two; I can't make this not work, so I'm wondering if it's a matter of not copying the keyframes instead of not pasting them... if that makes sense
5. Re: Copy and pasting keyframes from 1 graphic to another - PP won't let me
David Zeno Oct 28, 2010 7:16 PM (in response to shooternz)Hi shooternz
thanks !
I tried this, and bingo it worked. I saved it as a preset, and then dragged it from my bin to the new clip, and bingo it works.
thank you !
shooternz wrote:
Try this:
or
6. Re: Copy and pasting keyframes from 1 graphic to another - PP won't let me
David Zeno Oct 28, 2010 7:21 PM (in response to Colin Brougham)Hi Colin,
I am able to paste keyframes into the same clip, but even if I just highlight one keyframe, copy it to memory, and try to paste it to the new clip, it will not
paste.
Very strange.
Dave
7. Re: Copy and pasting keyframes from 1 graphic to another - PP won't let me
Bill Hunt Oct 31, 2010 11:54 AM (in response to David Zeno)David,
Maybe it's just jet-lag, but have you tried:
Selecting your animated Clip, when you have the desired Effects Keyframed, then Rt-clicking on that, and choosing Copy. Navigate to the desired destination Clip (note: a Duration match makes things much easier), and the Rt-clicking, and choosing Paste Attributes?
The Keyframed Effects will Copy to the destination Clip. See the above note on Duration.
Good luck, and if it is just jet-lag on my point, ignore my babble.
Hunt
