I try to set the timeout for my URLRequest via
var tempURLRequest:URLRequest = new URLRequest (path);
tempURLRequest.idleTimeout = 2000;
But it doesn't work. Thus: How can I set/change/get the timeout for URLRequests? I need this since I start many parallel URLRequests and on slow connections I get an IOError URL not found error due to the long time they are on stack (I asume).
Konrad
idleTimeout property is just for AIR 2 I think.
How do you load your URLRequest?
Can you show that part? with a loop?
The code to load a single image is:
var imageLoader:Loader = new Loader ();
imageLoader.contentLoaderInfo.addEventListener (Event.COMPLETE, loadHandler);
imageLoader.load (tempURLRequest);
And this function is called multiple (~500-3000) times in a "for" loop.
On fast connections all URLRequest are processed without any errors. On slow connections the later URLRequest get the "URL not found" error that I attribute to a timeout of the reqeusts.
