Hi Everybody, since Yesterday, my Flash Builder 4 has a lot of crashes with the message "Java Heap Space". I tried changing FlashBuilder.ini file to:
-Xms384m
-Xmx1024m
I changed also jvm.config in my /bin subfolder of my SDK to:
java.args=-Xms384m -Xmx1024m -Dsun.io.useCanonCaches=false
But nothing happened... I tried also removing and re-installing the builder with no success.
I have Windows XP Professional 32-bit with 3GB RAM
I have also a big .log file, if someone wants to see it, I can send it immediately...
Thanks !!!
Davide
I am in the same boat my friend. Uninstalled and reinstalled with no results, if anything made matters worse. Also since then Flash builder builds workpace on every save.
Now, afther changing the configuration parameters, Flash Builder uses 1,2 GB RAM and the whole CPU... but the project, when exported to release build, is more or less 3,5MB... What's the problem??? I tried uninstalling and installing again this morning...
Can you please send me your large log file? (to anirudhs (at) adobe dot com)
Anirudh
