LoadVars in flash media server 4 gives me HttpStatus 0. The same call in flash media server 3.5.1 works. Not sure what has changed in FSM 4 javascript engine related to encoding.
SessionID=9f2bc0eb%2d7d5d%2d42cf%2d9425%2db8211ee2b57e&filename=testfile%2eflv&contenttype=video%2fx%2dflv
Any pointers would be helpful.
I am putting the step in detail so that some can answer what has changed in FMS 4 for below call to fail.Below code works in 3.5.1.
var entry = new LoadVars();
entry.SessionID="fffd9f3d-4712-4fd4-b6bb-c56ea9a30fba";
entry.filename="test.flv";
entry.type="video/x-flv";
var resp = new LoadVars();
// resp had onData handle to process the resp.
entry.sendAndLoad("http://xyz:123456",resp,"POST");
Hi kanr ,
I tried this code on my FMS 4.0 server.
application.onAppStart = function() {
resp.onData = function(data) {
trace("onData" );
resp.onHTTPStatus = function(status) {
trace("status: "+status);
entry.sendAndLoad("http://localhost:8134/cgi-bin/test.pl",resp,"POST");
I do get the HTTP Status as expected i.e 200 in onHTTPStatus. Are you trying something different from this that is not working. If required, you can provide me more details on abh@adobe.com
Abhishek
Thanks for the reply.
If the HTTP response contains below header it is causing the problem. My
weblogic server was returning below header was causing issue in FMS 4. FMS
3.5.1 is able to handle the chunked responses.
Transfer-Encoding: chunked
