I'm using ColdFusion 8. I need help with Web Services and APIs. I can get the simple a convernsion from Celsius to Fahrenheit to work:
<cfinvoke
webservice = "http://webservices.daehosting.com/services/TemperatureConversions.wso?WSDL"
method="CelciusToFahrenheit"
nCelcius = "54"
returnvariable="foo"
<cfoutput>#foo#</cfoutput>
I can't get anything else to run. Is there a standard template, tool of dvelopment style that I can use to fill in information? Bellow is an API link for SPRACI, it is open an does not require an API key. Can some show me how to intergrate the functions into a web page. Or provide me with other examples that I can study? Thanks
Site with the SPRACI API:
http://www.spraci.com/services/soap/index.php?wsdl
Operation / Method Name |
What method are you trying to run?
What code are you using to run it?
What happens when you run that code?
Might something like this work?
<cfset AreaFetch = createobject("java","java.util.Hashtable")>
<cfscript>
AreaFetch.put("appkey", "the_appkey");
AreaFetch.put("username", "the_username");
AreaFetch.put("password", "the_password");
AreaFetch.put("area", "the_area");
AreaFetch.put("name", "the_name");
</cfscript>
<cfinvoke
webservice = "http://www.spraci.com/services/soap/index.php?wsdl"
method="area_getinfo"
inputStructArray ="#AreaFetch#"
<cfdump var="#foo#">
Bigpapa2,
have a look at the WSDL code provided by the service you want to call. All the services of the links you've provided rely on complexType definitions in the XML schema of the WSDL for sending their data.
Example:
area_getinfo expects a SOAP-packaged XML document fitting this complexType definition:
<xsd:all> | |
<xsd:element name="appkey" type="xsd:string"/> | |
<xsd:element name="username" type="xsd:string"/> | |
<xsd:element name="password" type="xsd:string"/> | |
<xsd:element name="area" type="xsd:string"/> | |
<xsd:element name="name" type="xsd:string"/> | |
</xsd:all> | |
</xsd:complexType> |
In your code you have to create a document structure that could be transferred into an XML document matching this by Apache Axis (the internal WS engine of CF). In this case a simple struct should do:
<cfscript>
abc = structNew();
abc["appkey"] = "whatever";
</cfscript>
If that doesn't work, try using JavaCast to make sure the typecasts get done correctly to String.
Also: Please read this article - it's the must read for everyone who's trying to deal with complex data structures in webservices consumed by CF:
http://tjordahl.blogspot.com/2008/04/reprint-consuming-web-service-complex.html
Cheers
Kai
I'm attempting to learn how to manage Web Services/APIs. I'm using ColdFusion 8 and the webservice is open (no key or password required). With my createobject I don't see where to include the operation or method (see list below) like was done with the <cfinvoke>. With <cfinvoke> I had save the document as wscfc.cfm is it the same with createobject? Thanks for the suggestions TheRealAgentK.
At the bottom of this page is a “Second Attempt” using the Put and <cfinvoke>. This modified code that was sent to me by BKBK (Thanks!). The error message follows the code.
I'm getting an error message (see below). Any help with this API or sample connections would be greatly appreciated.
?WSDL link below:
My script below (operation/method = area_list):
<cfscript>
stUser = structNew();
stUser.appkey = "";
stUser.username = "";
stUser.password = "";
stUser.area = "x0usa";
stUser.name = "";
ws = createObject("webservice", "http://www.spraci.com/services/soap/index.php?wsdl");
myReturnVar = ws.echoStruct(stUser);
</cfscript>
<cfoutput>#myReturnVar#</cfoutput>
Link to API notes:
C:\Users\djones\Documents\Affiliates\spraci\Webmaster Services SPRACI API SOAP area_list.mht
Operations /Methods below?
http://www.xmethods.net/ve2/WSDLAnalyzer.po;jsessionid=GuNmIhBRDeHT2vRN_L4c7nK8
Error Message Below:
Second attempt:
<cfscript>
AreaFetch.put("appkey", "");
AreaFetch.put("username", "");
AreaFetch.put("password", "");
AreaFetch.put("area", "x0usa");
AreaFetch.put("name", "");
</cfscript>
<cfinvoke
method="area_list"
Error message:
Are you sure one can invoke the web service with empty string data? Here is an example of the SOAP method with TheRealAgentK refers to:
<!--- WSDL --->
<cfset wsdl_url="http://www.spraci.com/services/soap/index.php?wsdl">
<cftry>
<!--- SOAP message to send to Web Service--->
<cfsavecontent variable="msg"><?xml version="1.0" encoding="UTF-8" ?>
<cfoutput><soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soapenv:Body>
<tns:data soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:tns="http://www.spraci.com/services/soap/">
<appkey xsi:type="xsd:string">1</appkey>
<username xsi:type="xsd:string">BKBK</username>
<password xsi:type="xsd:string">BKBK_pw</password>
<area xsi:type="xsd:string">USA</area>
<name xsi:type="xsd:double">USA</name>
</tns:data>
</soapenv:Body>
</soapenv:Envelope></cfoutput>
</cfsavecontent>
<!--- Invoke web service and send message--->
<cfhttp url="#wsdl_url#" method="post">
<cfhttpparam type="header" name="content-type" value="text/xml">
<cfhttpparam type="header" name="SOAPAction" value="">
<cfhttpparam type="header" name="content-length" value="#len(msg)#">
<cfhttpparam type="header" name="charset" value="utf-8">
<cfhttpparam type="xml" name="area_listRequest" value="#trim(msg)#">
</cfhttp>
<!--- Web Service response --->
<p><cfoutput>#xmlFormat(cfhttp.fileContent)#</cfoutput> </p>
<cfcatch type="any">
<cfdump var="#cfcatch#">
</cfcatch>
</cftry>
BKBK and The RealAgentK,
Much thanks. I'm just getting back to because the email went into my spam
account. I'll look into the empty string data.
Bigpapa2
