Locked
FlashBuilder 4 burrito install failed
Oct 25, 2010 Oct 25, 2010
Hi
my environment is
Windows XP
Flash Player 4 Premium installed.
I use "flashbuilder_burrito_p1_win_102510.exe"
folloing errors occurs.
install failed.
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 17 error(s), 19 warning(s)
WARNING: Payload {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX is already installed and the session payload {0B0C731E-5584-4980-A0D2-4ADC89220426} Adobe Flash Player 10 ActiveX has no upgrage/conflict relationship with it.
WARNING: Payload {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin is already installed and the session payload {A05D4EC5-033E-4446-9D96-1698FE490147} Adobe Flash Player 10 Plugin has no upgrage/conflict relationship with it.
WARNING: Payload {FB7F30B6-BFBF-4d2c-9F61-B5533659ACBE} Adobe Flash Player 10 Plugin is already installed and the session payload {A05D4EC5-033E-4446-9D96-1698FE490147} Adobe Flash Player 10 Plugin has no upgrage/conflict relationship with it.
WARNING: Payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder is already installed and the session payload {F50993F8-704F-4B21-AAC2-D91800CCF54C} Adobe Flash Builder has no upgrage/conflict relationship with it.
WARNING: Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
WARNING: Payload cannot be installed due to dependent operation failure
ERROR: Verifying payload integerity : Failed with code 1
ERROR: MsiConfigureProductEx failed with error: 1612
ERROR: The following payload errors were found during install:
ERROR:  - Microsoft_VC90_ATL_x86: Install failed
ERROR:  - Microsoft_VC90_CRT_x86: Install failed
ERROR:  - Adobe Flash Player 10 ActiveX: Install failed
ERROR:  - Microsoft_VC80_ATL_x86: Install failed
ERROR:  - AdobeHelp: Install failed
ERROR:  - Microsoft_VC90_MFC_x86: Install failed
ERROR:  - Suite Shared Configuration CS5: Install failed
ERROR:  - AdobeTypeSupport CS5: Install failed
ERROR:  - Microsoft_VC80_CRT_x86: Install failed
ERROR:  - Adobe Flash Player 10 Plugin: Install failed
ERROR:  - AdobeCMaps CS5: Install failed
ERROR:  - Microsoft_VC80_MFC_x86: Install failed
ERROR:  - Microsoft_VC80_MFCLOC_x86: Install failed
ERROR:  - Adobe Flash Builder: Install failed
"Adobe Flash Builder Burroto" in Add or Remove Program.
please help.
Installation and activation
9.4K
Thanks for sending your log entries.
Based on where the errors start in the log, the installer was unable to update your Visual Studio runtimes. There's a KB article here describing how to troubleshoot that by installing those runtimes manually:
http://kb2.adobe.com/cps/842/cpsid_84252.html
After resolving the VS runtimes:
- uninstall FB Burrito, and reboot.
- there should be a folder on your desktop containing the extracted Burrito installer, so you won't need to re-extract it again before re-installing.
Let us know how it goes,
-Chris
Been fighting this same issue all afternoon, Unable to install the Burrito. Tried two different machines. No go.
Guest
Oct 26, 2010 Oct 26, 2010
Had faced the same issue even after following the KB article as suggested by Agruss.
Finally executed the installer with Administrative privilges post which the installation
was successful.
-- JK
@JK
Can you share your steps? I'm stuck.
-DH
The steps for running as an Administrator differ depending on your version of Windows:
On WinXP:
- it's best to be logged in as a machine Admin during installation
- alternatively you can right click the exe, choose "Run as...", and then authenticate as a user with Admin rights.
On Vista and Win7:
- right click the installer exe, and choose "Run as administrator..."
- [aside: usually Vista and Win7 will prompt for elevated rights automatically, but if you have UAC disabled, it might require manual intervention.]
The original poster (hattrickbros) mentioned being on WinXP. For others of you seeing this problem, are you on WinXP too, or on a newer version of Win?
-Chris
Same setup/scenario as hattrickbros here. Logged in as admin. No luck. Same errors.
Guest
Oct 31, 2010 Oct 31, 2010
@DH
Sorry for the delayed response.
My envirnoment:
Win 7 Professional 32-bit
Flash Builder 4 Premium already installed
I had followed the steps as outlined in the KB article.
The VC components were successfully getting installed individually but the FB burrito installation was failing even after reboots.
Finally, executing it with Admin. privileges resulted in a succesful installation. No other additional steps were done apart from separately installing
all the VC components listed under the payload package of the installer.
... Maybe i was lucky...
-- JK
Similar problem installing on Windows Vista Home Premium. Only 13 errors and warnings as shown below, but no luck using the KB steps suggested above or anything else. Tried many times with Run as Administrator after restart, but nothing seems to work.
Chris
Exit Code: 7
- 0 fatal error(s), 13 error(s), 13 warning(s)
Oct 27, 2010 Oct 27, 2010
Hi Chris,
When you ran the steps in the KB article (http://kb2.adobe.com/cps/842/cpsid_84252.html) for installing the VC Runtimes individually, did those modules install successfully, or did you see a particular error message?
For example, if you get error 2203 when trying to install those MS VC runtimes individually, there's a KB article here describing how to fix that:
http://kb2.adobe.com/cps/408/kb408626.html
-Chris A.
Hi
I got an error message eg "ERROR:  - Microsoft_VC90_ATL_x86: Install failed".
so I try to install "Adobe Flash Builder Burrito Installer\Adobe Flash Builder Burrito\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi"
but installer says "already installed".
I launched "Adobe Flash Builder Burrito Installer\Adobe Flash Builder Burrito\Set-up.exe"
but same error occurs."ERROR:  - Microsoft_VC90_ATL_x86: Install failed".
Guest
Nov 01, 2010 Nov 01, 2010
I got the same error as hattrickbros, same error message and log output.
I am installing on a corporate pc and I don't have the administrator login.
Why does Flash Builder 4 install no problem on this machine but burrito throws the Exit Code 7 error?
Is there no way to install burrito without admin?
@Steve,
Is it fair to assume that you're on WinXP as well?
Generally, both FB4 and Burrito require elevated rights to install, so I have no explanation for why you were able to install FB4 successfully on that machine, but not Burrito. They both use virtually identical installer technology under the hood.
On WinXP, Power User rights are probably sufficient, without requiring full Admin rights. Often it's just easier to talk about Admin rights, because Vista and Win7 have the "run as administrator" context menu item, and automatic permission elevation via UAC, depending on how you have it configured.
What permission group does your login account belong to?
Here's one workaround for this you could try, that has helped some users with the VC Runtimes install problem on WinXP:
- download the latest Windows Installer Redistributable from MS: http://msdn.microsoft.com/en-us/library/aa372856%28v=VS.85%29.aspx
- if you can install that successfully, then see if you can then install Burrito without hitting the error.
-Chris
Guest
Nov 02, 2010 Nov 02, 2010
Chris,
Yes I am on Windows XP Pro SP2. I saw in the release notes that SP3 is required but unfortunately my company does not allow SP3 on our machines (don't know why).
My user account is a member of the Administrators group.
I was able to successfully run the Windows Installer update but that did not help.
I've attached my install log in case that helps.
Steve
Hi Steve,
I don't see the log you attached. Perhaps zip it up first, if you haven't already?
-Chris
Guest
Here's the log output:
Exit Code: 7
- 0 fatal error(s), 16146 error(s), 5 warning(s)
WARNING: Payload {5EE868D6-7B6B-49ee-AF60-09B1358AFFD7} Adobe Flash Player 10 ActiveX is already installed and the session payload {0B0C731E-5584-4980-A0D2-4ADC89220426} Adobe Flash Player 10 ActiveX has no upgrage/conflict relationship with it.
ERROR: 16215 Unable to create symlink at "C:\Documents and Settings\All Users\Start Menu\Programs\Adobe Flash Builder Burrito.lnk"
ERROR: 16215 Command ARKCreateSymlinkCommand failed.
ERROR: 16215 Unable to delete symlink at "C:\Documents and Settings\All Users\Start Menu\Programs\Adobe Flash Builder Burrito.lnk". Error 2 The system cannot find the file specified.
ERROR: 16215 Error rolling back command ARKCreateSymlinkCommand
ERROR: 16100 Unable to delete directory "K:\Program Files\Adobe\Adobe Flash Builder Burrito\Adobe Flash Builder Burrito\eclipse\p2". Error 3 The system cannot find the path specified.
ERROR: 16100 Error rolling back command ARKCreateDirectoryV2Command
ERROR: 16099 Unable to delete directory "K:\Program Files\Adobe\Adobe Flash Builder Burrito\Adobe Flash Builder Burrito\eclipse\plugins". Error 3 The system cannot find the path specified.
ERROR: 16099 Error rolling back command ARKCreateDirectoryV2Command
ERROR: 16098 Unable to delete directory "K:\Program Files\Adobe\Adobe Flash Builder Burrito\Adobe Flash Builder Burrito\eclipse\features". Error 3 The system cannot find the path specified.
ERROR: 16098 Error rolling back command ARKCreateDirectoryV2Command
ERROR: 16093 Unable to delete directory "K:\Program Files\Adobe\Adobe Flash Builder Burrito\Adobe Flash Builder Burrito\eclipse\configuration". Error 3 The system cannot find the path specified.
ERROR: 16093 Error rolling back command ARKCreateDirectoryV2Command
ERROR: 16092 Unable to delete file copy at "K:\Program Files\Adobe\Adobe Flash Builder Burrito\Adobe Flash Builder Burrito\eclipse\configuration\config.ini" Error 3 The system cannot find the path specified.
ERROR: 16092 Error rolling back command ARKMoveFileCommand
ERROR: 16091 Unable to delete directory "K:\Program Files\Adobe\Adobe Flash Builder Burrito\Adobe Flash Builder Burrito\eclipse\configuration". Error 3 The system cannot find the path specified.
bazillion more error lines just like those above, removing for brevity
ERROR: 32 Unable to delete file copy at "K:\Program Files\Adobe\Adobe Flash Builder Burrito\Adobe Flash Builder Burrito\eclipse\eclipsec.exe" Error 3 The system cannot find the path specified.
ERROR: 32 Error rolling back command ARKMoveFileCommand
ERROR: 31 Unable to delete file copy at "K:\Program Files\Adobe\Adobe Flash Builder Burrito\Adobe Flash Builder Burrito\eclipse\eclipse.exe" Error 3 The system cannot find the path specified.
ERROR: 31 Error rolling back command ARKMoveFileCommand
ERROR: 30 Unable to delete directory "K:\Program Files\Adobe\Adobe Flash Builder Burrito\Adobe Flash Builder Burrito\eclipse". Error 2 The system cannot find the file specified.
ERROR: 30 Error rolling back command ARKCreateDirectoryCommand
ERROR: 15 Deleting Registry Key - failure. Error 5
ERROR: 3 Unable to delete file copy at "K:\Program Files\Adobe\Adobe Flash Builder Burrito\Adobe Flash Builder Burrito\FlashBuilder.exe" Error 3 The system cannot find the path specified.
ERROR: 3 Error rolling back command ARKMoveFileCommand
ERROR: 2 Unable to delete file copy at "K:\Program Files\Adobe\Adobe Flash Builder Burrito\Adobe Flash Builder Burrito\.eclipseproduct" Error 3 The system cannot find the path specified.
ERROR: 2 Error rolling back command ARKMoveFileCommand
ERROR: 1 Unable to delete directory "K:\Program Files\Adobe\Adobe Flash Builder Burrito\Adobe Flash Builder Burrito". Error 2 The system cannot find the file specified.
ERROR: 1 Error rolling back command ARKCreateDirectoryCommand
Nov 03, 2010 Nov 03, 2010
Hi Steve,
Thanks for posting your install log - that really helps a lot.
Generally it's the first few errors that are most useful, and the rest are consequential.
The second error showing in your log is this one:
That makes me wonder if there's a permissions problem blocking installation. If you try creating a shortcut in that same location manually, are you able to?
For example, try creating a shortcut in that same path to some other exe that you have on drive K, and see if it works.
Also, what type of disk is drive K that you're trying to install to:
- local drive, or a network location?
- Fat32 or NTFS?
- internal drive, external, USB?
-Chris
Guest
You're onto something Chris.  I tried to create a shortcut in that same location and I was not able to do it.  It pops a warning dialog that says "unable to create shortcut".
My K: drive is a local internal hard drive formatted for NTFS.
Guest
Nov 05, 2010 Nov 05, 2010
Finally figured out my problem.
Remember I said this is a company computer I was trying to install on.  My company uses McAfee antivirus software.  I prefer to call it "Anti-Productivity Software".
Turns out there was an Antivirus rule (access protection) that was blocking the creation of shortcuts on my computer.  Apparently my company's security team had pushed out this new rule a couple months back in response to some PDF exploit that was going on involving the creation of shortcuts.  After that outbreak subsided they subsequently removed the rule but forgot to remove the rule from one of the groups which just happened to include my computer.
I notified our McAfee antivirus administrator of the problem and he removed the rule from my group and voila... I can create shortcuts again.  Burrito installed fine after that.
Don't you just love security stuff?  They make us so secure that we can't get anything done.
Jan 01, 2011 Jan 01, 2011
I've had a similar problem trying to install Burrito and Panini on Windows Vista. Both installed no problem for me on Windows 7. Here is the error I am getting. I've tried several times and still can't get it to install.
Exit Code: 7
- 0 fatal error(s), 20 error(s), 18 warning(s)
WARNING: Payload {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin is already installed and the session payload {00C5CA45-DFBA-4ceb-9DF2-E932233CCF68} Adobe Flash Player 10 Plugin has no upgrage/conflict relationship with it.
WARNING: Payload {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX is already installed and the session payload {B65AD0E3-C64A-4b91-BAEF-0EA667697FB1} Adobe Flash Player 10 ActiveX has no upgrage/conflict relationship with it.
ERROR:  - Adobe Media Player: Install failed
ERROR:  - Adobe Flash Catalyst Panini: Install failed
ERROR:  - Adobe Player for Embedding: Install failed
ERROR:  - Adobe Media Encoder CS5 X64: Install failed
ERROR:  - Adobe Flash Fonts1: Install failed
ERROR:  - Microsoft_VC90_ATL_x86_x64: Install failed
ERROR:  - Microsoft_VC90_CRT_x86_x64: Install failed
ERROR:  - Microsoft_VC90_MFC_x86_x64: Install failed
ERROR:  - Adobe AIR: Install failed
@Steve
The Admin rights thing has not worked for me. I have admin rights on two windowsXP machines. And FB4 installed on both windowsXP machines. I have followed all of the tips noted in this forum. And have been unable to install Burrito...finally gave up. I figure it will get sorted at some point.
-DH
When I tried to execute the MS redistributable payloads, they said
"source is not available" or something similar. I solved it by copying
the relevant payloads from my CS5 disk
Yup same thing here, exit code 7 etc etc.... In my laptop (Win 7 x64 home) installed fine. On my desktop (Win 7 x64 Ultimate) nothing....
Hi Mike,
If you look in your installer logs, can you paste the first few errors showing? There's info here about how to get to your logs:
http://kb2.adobe.com/cps/844/cpsid_84451.html
If you're seeing the notorious errors about the VC Runtimes failing to install, have you already tried the troubleshooting page here:
-Chris
Thanks for the response,
I finally managed to install the Flash Builder "Burito" by navigating to the
installer directory and manually installing the VCRuntimes manually with
administrator privileges, and then run the installer normally. That did it
for me.
Note: I also decided to install to a directory with no special Characters or
anything in the name. like C:/Burito/
Hope it helps someone.
Michael Dobekidis
NetGFX.com
email at: contact@netgfx.com
