I'm dumping the output of a query into an excel file using application/vnd.ms-excel in my code and I need to know if there is a way to freeze the header row so it stays at the top when the user scrolls down the list.
Not if you are just sending CSV data with the vnd.ms-excel content type to tell the browser to send the CSV data to that application.
POSSIBLY if you where to use the POI and|or CF9 <cfspreadsheet...> tag. But I would not be surprised if an Excel User Interface detail like that is something that is NOT exposed to either of those Application Interfaces.
Yes, you would need to create a true spreadsheet. But it is possible with with either CF9 (or earlier using POI)
http://help.adobe.com/en_US/ColdFusion/9.0/CFMLRef/WS89BB5273-80BA-4c55-9862-4D9D0ADA062B.html
http://poi.apache.org/spreadsheet/quick-guide.html#Splits
-Leigh
I forgot about one another option. You should be able to do this using html/xml. I do not have the mso schemas reference handy. But you can easily view the xml syntax by creating a sample spreadsheet (freezing the panes) and saving it as html.
-Leigh
Here is an example of the xml/html method
http://www.bennadel.com/blog/467-Freezing-Row-Column-Panes-In-Excel-XML.htm
NEAT
Extremely simple too. ( I do not know why I always forget about that option ...
Thank you all.
