RH HTML 8.0.2
Workflow: Creating procedures for using icons in the GUI--like those on this posting interface, the labels appear in tooltips, so writing proc as "Click the <icon.jpg> <href link to a topic> [tooltip name of icon] </a> to add a table." as seen below:
<?rh-list_start class="NumProc" ?><p class="Numlist">On the toolbar, click <img src="icon.jpg" style="border: none;"
width="24" height="25" border="0" /> [<a href="About_Icon.htm">Palette</a>], click the <span style="font-weight: bold;">Footnotes</span> tab, and then
click <img src="newicon.jpg" style="border: none;" width="23" height="25" border="0" /> [New Footnote].</p><?rh-list_end ?>
In the published help, both icons are offset to the right into the the modifying tooltip word in braces...perhaps a function of the number of characters in between the braces.
Also, I see "function(){return A.apply(null,[this].....concatenated arguments" in a tooltip popup when I'm typing this note...does RoboHelp require an escape key for straight braces?
You can see the output in step 3 on http://docs.ubmatrix.com/webhelp/RBME/3_6/Tutorial_Mapping_a_Footnote.htm. Is this a defect?
Using the link you provided, I don't see the image displaced, nor do I see a popup. Can you provide screenshots of what is going wrong? Also, what browser (version) are you using? It looks ok to me in FF, IE and Chrome.
Greet,
Willam
Willam--this problem lasted 3 days....and multiple publishing attempts. The fact that it is "repaired" I attribute to your visit. Thanks! The popup is in the app, not in the OLH. I apologize for any confusion -- or delete, if you wish.
Glad your problem is solved, altough I didn't do anything. Guess I'm a magician or something
Greet,
Willam
