10 Replies Latest reply: Nov 6, 2010 11:10 AM by Jim Hefley RSS
    How do I display the Layers Panel?
    Jim Hefley Community Member
      I am a new user of  Photoshop Elements 8. On the Adobe website Help, it says "to show the Panel Bin, choose
      Window>Panel Bin"a, which should then display Effects in the top section and Layers in the lower section.
      However, when I do this, which essentially puts a check mark by Panel Bin, nothing else happens, and the Panel
      Bin does not appear on the right side of my workspace. What do I need to do?
      Thank you.
        • 1. Re: How do I display the Layers Panel?
          99jon Community Member
          On the top menu click Window >Layers
          • 2. Re: How do I display the Layers Panel?
            Barbara B. CommunityMVP
            Try clicking Reset Panels at the top of the window, over towards the right side.
            • 3. Re: How do I display the Layers Panel?
              Thanks for your suggestion. I did click on Window>Reset Panels. Nothing really happened, and no
              check mark appeared next to Reset Panels like  it does when you click on Window>Panel Bin. I must
              be omitting some more macro setting or some other previous step that the instructions assume I have done.
              On the Menu Bar at the far left it does display Photoshop Elements --however, I do not show a Shortcuts bar
              like it shows in my Photoshop Elements5 for Dummies ( I don't have this book for Elements 8 but I assume
              most of the basic stuff is still correct).
              In the Photoshop class I recently attended, somehow the Layers Panel magically appeared on the screen of the
              Dell PC we used in the class and we then moved on to learning the functions in the Tool Bar.
              That is why it is so puzzling and so frustrating that I cannot get the Layers Panel to be displayed!
              What else can you suggest?
              Thanks, JIm
              • 4. Re: How do I display the Layers Panel?
                Thanks for your suggestion but as I indicated in my request for help, that is what I have done, and
                nothing happens. Is there some previous macro step that I should have done before clicking on Window-Panel Bin?
                Because when I do this exact step you recommend, the Panel Bin does NOT appear--nothing seems to happen.
                What else do you suggest?
                Thanks, Jim
                • 5. Re: How do I display the Layers Panel?
                  I suspect you are not in Full Edit. Click the triangle to the right of  where it says Edit (in the orange section), and choose EDIT Full. If not, you'd better post a screenshot of exactly what you do see.
                  • 6. Re: How do I display the Layers Panel?
                    Thanks-I realized when I got this message that I had neglected to mention that I am on Mac and not a PC, and
                    I am discovering that it makes a difference with Elements in some instances.
                    I went to our local Apple store today and found a technician who uses Elements, although he  probably is not
                    at the expert level you are. After fiddling around with my computer for a while, he discovered  that somehow
                    the zoom out had been enabled to such an extent that the Layers Panel was there but off in space, and when he
                    zoomed back in we discovered I did have the panel where it belonged.
                    I really appreciate your assistance, and hope you will be willing to help again in the future.
                    Thanks, Jim
                    Begin forwarded message:
                    Date: November 2, 2010 10:11:05 PM EDT
                    To: Jim Hefley <jhefley@charter.net>
                    Subject: How do I display the Layers Panel?
                    Reply-To: clearspace-442795804-843662-2-3249557@mail.forums.adobe.com
                    • 7. Re: How do I display the Layers Panel?
                      Barbara-
                      You may recall you tried to assist me a few days ago in how to display the Layers Panel. It was resolved temporarily
                      when I got help at the local Apple store. I am a new PSE user on a MacBook Pro.
                      I started working with Layers then had a Adobe "crash". When I restarted PSE, I no longer have the Task Pane line of
                      icons with ORGANIZE, FIX, SHARE AND CREATE boxes on the right. And the Layer Panel no longer shows up
                      in the lower section on the right.
                      I bought the Adobe Photoshop Elements 8 "Classroom  in a Book" at the Apple store. It talks about how to go from
                      Organizer to Edit and vice-versa, but it never states how to get the icons to appear--I guess it assumes the Task Pane and
                      the Organizer icon will automatically appear when I open PSE.
                      How do I restore the Task Pane so I then can click on FIX and then FULL EDIT mode?
                      Thanks Jim
                      • 8. Re: How do I display the Layers Panel?
                        Barbara-
                        Thanks Jim
                        • 9. Re: How do I display the Layers Panel?
                          First try deleting the prefs. Quit PSE, then relaunch while holding down command+shift+option. Keep holding the keys till you see a window asking if you want to delete the settings file. You do.
                          If that doesn't do it, can you post a screenshot here of what you do see?
                          • 10. Re: How do I display the Layers Panel?
                            Barbara-that seems to work-I am not sure exactly what I deleted in
                            deleting the settings file"but I assume it will work fine
                            Thanks Jim
                            Jim
