After setting a default page in IIS or whatever server you
use, you can pull out the cgi variable from the url. for example
www.mysite.com/searchpage. Then it redirects to the default page -
on the default page, you need to pull out the CGI variable, such as
cgi.path_info, and then do a cf include template = "#your
variable#".
that should get you the effect you need... just search a
little on cgi variables and write your default page.
