My Webhelp output option is corrupt and I don't know how to fix it. All other outputs work right but not the one I need. I have tried deleting and creating a new Webhelp SSL but I get the same problem, the TOC is moved to the right about a half inch.
I tried to create a new blank project, blank topic, default css, default skin and run Webhelp and I still have the same problem. I also viewed it in a different browser.
Do I need to uninstall RH?
Pink shows space, where it should be tight against the left side. Doesn't occur in Flash, or Webhelp pro or chm.
Which RH version are you using?
What happens if you start a new project and create WebHelp output? Also, try the example projects.
When did the problem occur first? Have you changed the skin or one of the RH output files? There may be something in whthost.js, but before looking into that, it's best to make sure that it's not project related.
Greet,
Willam
Your screenshot is of that of the WebHelp Skin Editor, not the TOC from RH source or RH WebHelp output.
Inquiring minds want to know...
Good luck,
Leon
I have unistalled RH8 and reinstalled it and I still get the same error.
The picture is from the Webhelp output, it does not look like that in my project.
I checked the gsMargin="0" and it is zero.
The odd thing is that I will create a new SSL for the webhelp and it will work several times and then it will stop working. I am experiencing the same strange error in all of my projects. Including the new blank project using all defaults including the skin that comes with RH. Also, I have tried other skins included with RH and they don't work either.
I do not get this error when I use WebHelp Pro, but it doesn't have the Publish feature which I need for SVN, so I can't use it.
I think I have a ghost in my machine. There probably isn't a fix. Thanks for trying.
The fact it works but then suddenly stops make me think this is a resourcing issue. Have you tried using a different location (maybe on a local drive) and see if the same problem occurs.
BTW the WebHelp Pro output is designed to be used with the RoboHelp Server application. If you don't have this the publish option is not available. You can find out more about RoboHelp Server here.
The RoboColum(n) | @robocolumn | Colum McAndrew |
I am only using it on my local PC. I just tried shutting down all programs and only running RH and I have the same error. Then I created a new build no more error. Maybe something is gunking up my computer.
