1. Re: Filters - Render
Gyno-jiz Nov 4, 2010 9:19 PM (in response to Mark A Goodwin)Not available in 64-bit mode. Get info on the app, and click the open in 32-bit mode checkbox. Then the filter will be available (along with the penalties of 32-bit mode).
2. Re: Filters - Render
Mark A Goodwin Nov 5, 2010 4:47 AM (in response to Gyno-jiz)Hi
Thanks for the reply, however, not sure what you mean by "Get info on the app". If I'm correct I'm working in 8-bit mode?
Mark
3. Re: Filters - Render
charles badland Nov 5, 2010 6:51 AM (in response to Mark A Goodwin)Thanks for the reply, however, not sure what you mean by "Get info on the app". If I'm correct I'm working in 8-bit mode?
Mark,
8-bit mode refers to the bit depth of an image. The 32 and 64 bit modes describe the CPU's architecture. Two totally different things.
To get Lighting Effects back:
Close Photoshop
From Finder go Go>Applications>Adobe Photoshop CS5 folder>Adobe Photoshop CS5 application.
With the CS5 application highlighted, go File>Get Info and check "Open in 32 Bit Mode" in the General Get Info window.
Relaunch Photoshop.
You should see Lighting Effects again!
4. Re: Filters - Render
Mark A Goodwin Nov 5, 2010 9:04 AM (in response to charles badland)Brilliant...I understand.
Thank you very much for your patience
Mark
