Hi.
I created a Application with new Adobe Flashbuilder Buritto. I tested it with the integrate Runtime , its works.
But i cant test it on Android Emulator, because the installation of my .apk File doesnt work.
First: i installed the Runtime_Emulator_Froyo_20100930 on the Device
and then i tried to install my Apk File but i got the message : Failure [INSTALL_FAILED_INVALID_APK]
how can i fix it?
smoo
APK packages created by Flash Builder "Burrito" are not intended to use on emulators. If you would like to create an apk package that can run on an Android emulator, you can use the AIR ADT command-line tool.
Here is the information about this: http://help.adobe.com/en_US/air/build/WSfffb011ac560372f-5d0f4f25128cc9cd0cb-7ffb.html
Sedat Akkus
Computer Scientist, Flash Builder
