Hello
Not sure if this is a known bug.. I had just opened FB this morning, and clicked the editor tab for a file (which was still there from my last session). Instead of seeing the editor, I got this exception:
java.lang.NullPointerException
at com.adobe.flexide.editorcore.ColoringAndStylingPreferenceManager.getColoringAndStylingConfiguration(ColoringAndStylingPreferenceManager.java:129)
at com.adobe.flexide.as.core.ASCoreSourceViewerConfig.getPartitionScannerMap(ASCoreSourceViewerConfig.java:137)
at com.adobe.flexide.as.core.ASCoreSourceViewerConfig.addDamagerRepairers(ASCoreSourceViewerConfig.java:150)
at com.adobe.flexide.as.core.ASCoreSourceViewerConfig.getPresentationReconciler(ASCoreSourceViewerConfig.java:98)
at org.eclipse.jface.text.source.SourceViewer.configure(SourceViewer.java:366)
at com.adobe.flexide.editorcore.editor.FlexSourceViewer.configure(FlexSourceViewer.java:234)
at org.eclipse.ui.texteditor.AbstractTextEditor.createPartControl(AbstractTextEditor.java:3322)
at org.eclipse.ui.texteditor.StatusTextEditor.createPartControl(StatusTextEditor.java:53)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.createPartControl(AbstractDecoratedTextEditor.java:427)
at com.adobe.flexide.editorcore.editor.AbstractFlexEditor.createPartControl(AbstractFlexEditor.java:835)
at com.adobe.flexbuilder.as.editor.ActionScriptEditor.createPartControl(ActionScriptEditor.java:97)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:662)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:462)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1209)
at org.eclipse.ui.internal.PartStack.presentationSelectionChanged(PartStack.java:843)
at org.eclipse.ui.internal.PartStack.access$1(PartStack.java:829)
at org.eclipse.ui.internal.PartStack$1.selectPart(PartStack.java:139)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation$1.handleEvent(TabbedStackPresentation.java:133)
at org.eclipse.ui.internal.presentations.util.AbstractTabFolder.fireEvent(AbstractTabFolder.java:270)
at org.eclipse.ui.internal.presentations.util.AbstractTabFolder.fireEvent(AbstractTabFolder.java:279)
at org.eclipse.ui.internal.presentations.defaultpresentation.DefaultTabFolder.access$1(DefaultTabFolder.java:1)
at org.eclipse.ui.internal.presentations.defaultpresentation.DefaultTabFolder$2.handleEvent(DefaultTabFolder.java:87)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1012)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:770)
at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:3256)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:2045)
at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:323)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3473)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2221)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:493)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at com.adobe.flexbuilder.standalone.FlexBuilderApplication.start(FlexBuilderApplication.java:109)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:559)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
Was the project closed or deleted before you opened editor? Can you provide more details to reproduce the problem?
-radhakrishna
The project was not closed. I had just started my PC, opened FB and encountered the problem. Other editors failed to open as well.
I then closed FB, opened it again and the bug did not appear again.
Good morning...
Another Monday and the same problem again.
I just checked the log and found a few interesting exceptions, which should get yuou started:
!SESSION 2010-10-25 09:07:52.829 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_16
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY com.adobe.flexbuilder.project 4 43 2010-10-25 09:08:00.051
!MESSAGE Couldn't register *ColoringAndStylingPreferenceProvider
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "com.adobe.flexide.as.core" was unable to instantiate class "com.adobe.flexide.as.core.color.ActionScriptColoringAndStylingPreferenceProvider".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:180)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:874)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:51)
at com.adobe.flexide.editorcore.EditorCore.registerColoringAndStylingPreferenceProviders(EditorCore.java:246)
at com.adobe.flexide.editorcore.EditorCore.start(EditorCore.java:216)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:352)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:280)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:408)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:211)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:381)
at org.eclipse.osgi.internal.loader.SingleSourcePackage.loadClass(SingleSourcePackage.java:33)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:454)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:398)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.defineClass(DefaultClassLoader.java:183)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineClass(ClasspathManager.java:576)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findClassImpl(ClasspathManager.java:546)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClassImpl(ClasspathManager.java:477)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass_LockClassLoader(ClasspathManager.java:465)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:445)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:457)
at com.adobe.flexbuilder.as.editor.ui.views.CallHierarchyView.<init>(CallHierarchyView.java:418)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:170)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:267)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:263)
at org.eclipse.ui.internal.registry.ViewDescriptor.createView(ViewDescriptor.java:63)
at org.eclipse.ui.internal.ViewReference.createPartHelper(ViewReference.java:324)
at org.eclipse.ui.internal.ViewReference.createPart(ViewReference.java:226)
at org.eclipse.ui.internal.ViewPane.setVisible(ViewPane.java:529)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:668)
at org.eclipse.ui.internal.PartStack.createControl(PartStack.java:576)
at org.eclipse.ui.internal.PartSashContainer.createControl(PartSashContainer.java:568)
at org.eclipse.ui.internal.PerspectiveHelper.activate(PerspectiveHelper.java:272)
at org.eclipse.ui.internal.Perspective.onActivate(Perspective.java:982)
at org.eclipse.ui.internal.WorkbenchPage.onActivate(WorkbenchPage.java:2626)
at org.eclipse.ui.internal.WorkbenchWindow$27.run(WorkbenchWindow.java:2965)
at org.eclipse.ui.internal.WorkbenchWindow.setActivePage(WorkbenchWindow.java:2946)
at org.eclipse.ui.internal.WorkbenchWindow$21.runWithException(WorkbenchWindow.java:2263)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3855)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3476)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$28.runWithException(Workbench.java:1384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
Caused by: java.lang.ClassCircularityError: com/adobe/flexide/editorcore/document/IFlexDocument
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Unknown Source)
at java.lang.Class.getConstructor0(Unknown Source)
... 105 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-10-25 09:08:00.053
!MESSAGE Plug-in "com.adobe.flexide.as.core" was unable to instantiate class "com.adobe.flexide.as.core.color.ActionScriptColoringAndStylingPreferenceProvider".
!STACK 0
!ENTRY com.adobe.flexbuilder.project 4 43 2010-10-25 09:08:00.452
!MESSAGE Couldn't register *FileTemplatesProvider
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "com.adobe.flexide.as.core" was unable to instantiate class "com.adobe.flexide.as.core.filetemplates.ActionScriptFileTemplatesProvider".
at com.adobe.flexide.editorcore.EditorCore.registerFileTemplatesProviders(EditorCore.java:275)
at com.adobe.flexide.editorcore.EditorCore.start(EditorCore.java:217)
... 105 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2010-10-25 09:08:00.454
!MESSAGE Plug-in "com.adobe.flexide.as.core" was unable to instantiate class "com.adobe.flexide.as.core.filetemplates.ActionScriptFileTemplatesProvider".
!STACK 0
!ENTRY com.adobe.flexbuilder.editorcore 4 1 2010-10-25 09:26:00.444
!MESSAGE Error creating pages for Code and Design editor
!STACK 0
at com.adobe.flexide.as.core.color.FastActionScriptScanner.<init>(FastActionScriptScanner.java:327)
at com.adobe.flexide.mxml.core.editor.MXMLCoreSourceViewerConfig.getPartitionScannerMap(MXMLCoreSourceViewerConfig.java:234)
at com.adobe.flexide.mxml.core.editor.MXMLCoreSourceViewerConfig.getPresentationReconciler(MXMLCoreSourceViewerConfig.java:257)
at com.adobe.flexbuilder.mxml.editor.code.MXMLCodeEditor$MXMLSourceViewer.configure(MXMLCodeEditor.java:577)
at com.adobe.flexide.editorcore.editor.AbstractModelAwareEditor.createPartControl(AbstractModelAwareEditor.java:50)
at com.adobe.flexbuilder.mxml.editor.code.MXMLCodeEditor.createPartControl(MXMLCodeEditor.java:304)
at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEditorPart.java:242)
at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEditorPart.java:212)
at com.adobe.flexbuilder.editorcore.editor.CodeAndDesignEditor.createPages(CodeAndDesignEditor.java:209)
at com.adobe.flexbuilder.mxml.editor.MXMLEditor.createPages(MXMLEditor.java:217)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:357)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1608)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:778)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:677)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:638)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2854)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2762)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2754)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2705)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2701)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2685)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2676)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileAction.java:99)
at org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystemEditorAction.java:99)
at org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAction(OpenActionGroup.java:133)
at com.adobe.flexbuilder.editors.derived.ui.navigator.FlexMainActionGroup.runDefaultAction(FlexMainActionGroup.java:350)
at org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen(ResourceNavigator.java:787)
at org.eclipse.ui.views.navigator.ResourceNavigator$6.open(ResourceNavigator.java:499)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:842)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
at org.eclipse.core.runtime.Platform.run(Platform.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:840)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1101)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1205)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:264)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:258)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:298)
!ENTRY org.eclipse.ui 4 0 2010-10-25 09:26:00.586
!MESSAGE Unable to create editor ID com.adobe.flexbuilder.editors.mxml.MXMLEditor: assertion failed:
!STACK 0
org.eclipse.core.runtime.AssertionFailedException: assertion failed:
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:110)
at org.eclipse.core.runtime.Assert.isTrue(Assert.java:96)
at org.eclipse.ui.part.MultiPageEditorPart.setActivePage(MultiPageEditorPart.java:1074)
at com.adobe.flexbuilder.editorcore.editor.CodeAndDesignEditor.setActivePage(CodeAndDesignEditor.java:683)
at com.adobe.flexbuilder.mxml.editor.MXMLEditor.setActivePage(MXMLEditor.java:544)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:361)
!ENTRY org.eclipse.ui 4 0 2010-10-25 09:27:07.095
!MESSAGE Unable to create editor ID com.adobe.flexbuilder.editors.actionscript.ActionScriptEditor: An unexpected exception was thrown.
!STACK 0
It would be great if you are able to give specific steps to reproduce the issue. It seems it doesn't happen always for you.
Can you please log a bug in jira https://bugs.adobe.com/flex with reproducible steps and log.
-Radhakrishna
I had a similar problem when tried to run Modeling plug-in on Eclipse 3.6 thus discovering that the plug-in is incompatible with Eclipse 3.6
stack trace is similar
see also http://forums.adobe.com/thread/748772 for more details
I hope this helps
