Hi everyone!
During the project migration to Flash CS5 I discovered an unexpected problem. If the scene contains at least one component of the TFL, then the all flashvars variables are "undefined". Delete a component from the scene, compile - all works fine. Adds - again undefined.
FlashPlayer 10,0,45,2
Sorry from my English
Found the same issue.
I can reproduce the issue. I've started the wheels turning to figure out what's going on.
OK - it looks like this is an issue with the Flash Pro CS5 preloader code. I'm told there will be a technote published for this problem.
Here's a workaround I got from the engineer who looked into this:
Typically you could access the flashvars parameters in AS3 by doing something like this:
var params:Object = loaderInfo.parameters;
But to work around the issue we are having with the TLF RSL preloading, you need a little bit of extra code:
if (parent != null && parent.parent != null) {
params = parent.parent.loaderInfo.parameters;
For the work around to work correctly THIS CODE NEEDS TO BE ON FRAME ONE. It cannot be in a user defined constructor (too early) and it cannot be in frame two (too late). We need to be clear about that.
While there is not a schedule for releasing a fix to this issue, we definitely would want users to first grab the flashvars the normal way and then check parent != null && parent.parent != null, because I hope that in the future we will be able to fix this issue, and we do not want users creating content that would be incorrectly applying a work around when one is no longer necessary. So definitely those checks are important.
Alan
Just for the record, if you are having a problem accessing your FlashVars (and you are using a TLFTextField in Flash CS5) and you are using external classes (i.e. you have a document class and not timeline code) you need to listen for the ADDED_TO_STAGE event before trying to access them.
For example ...
package
import flash.display.Sprite;
import flash.events.Event;
import flash.display.LoaderInfo;
public class Main extends Sprite
public function Main():void
if (stage) init();
else addEventListener(Event.ADDED_TO_STAGE, init);
private function init(evt:Event = null):void
removeEventListener(Event.ADDED_TO_STAGE, init);
// You can now loop through the params to access your FlashVars
Going up 2 levels was too far for my case.
This worked for me:
/** * CS5 completely broke flashVars. * See http://forums.adobe.com/thread/644057 for details. * Basically, ADOBE == STUPID. Thanks guys! */ private function getFlashVar( varName:String ) :String { var paramObj:Object = LoaderInfo(this.root.loaderInfo).parameters; if( parent != null ) { paramObj = parent.loaderInfo.parameters; }// end if() try { for( var el:String in paramObj ) if( el == varName ) return paramObj[el].toString(); } catch(e) { return ""; }; return ""; }
Just another example of the folks at Adobe screwing up a good thing.
