1. Re: AIR app doesn´t recognize SWF files
chris.campbell Nov 9, 2010 10:08 AM (in response to Petteri_Paananen)Hi,
That's odd that this just started occurring for the customer. A couple of things come to mind, first, are you using FileFiters when you call browseForOpen()? If you are, could you try a test where you remove them and then see if the swf's become enabled? Do the swf files have extensions on the mac? If not, try adding them and see if that makes a difference.
If you'd like, I can also give this a try since I have both platforms available to me. Could you attach or email me (ccampbel@adobe.com) some sample code and a sample swf that would illustrate the problem?
Chris
2. Re: AIR app doesn´t recognize SWF files
Petteri_Paananen Nov 9, 2010 9:32 PM (in response to chris.campbell)Thanks for your answer Chris. My problem is that I can´t reproduce that problem. Everything works fine here in my computer, even same SWF files that my client sent me for testing. We also have a lot´s of other users and none of them has complaint so I guess there has to be some problems with my client´s computer...
FileFilters is in use, I´ll try to remove it, thanks for the tip.... If it manage to reproduce and isolate that problem, I might need some further help. I´ll get back to you then. Thanks....=)
