I have an awkward issue when updating an application lca in LiveCycle. Although everything is currently cleaned up, so no instances of the previous application version are running when the new lca is imported, i get an exception in the logs, java.io.OptionalDataException, and all assigned tasks are stalled. What is even stranger, is if I turn on recording on the process containing the AssignTask and start another instance of the process, everything works correctly, no stalled actions...
Has anybody experienced this issue? Any help would be highly appreciated...
Exception stack trace:
java.io.OptionalDataException: java.lang.RuntimeException: java.io.OptionalDataException
at com.adobe.idp.jobmanager.execution.InternalJobManager.deserializeObject(InternalJobManager.java:1368)
at com.adobe.idp.jobmanager.execution.InternalJobManager.createJob(InternalJobManager.java:104)
at com.adobe.idp.jobmanager.service.JobManagerService.createJob(JobManagerService.java:82)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:585)
at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.java:118)
at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor.java:140)
at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptorChainImpl.java:60)
at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassivationInterceptor.java:53)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(TransactionInterceptor.java:74)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTransactionCMTAdapterBean.java:357)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doSupports(EjbTransactionCMTAdapterBean.java:227)
at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EJSLocalStatelessEjbTransactionCMTAdapter_caf58c4f.doSupports(Unknown Source)
at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvider.java:104)
at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInterceptor.java:72)
at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStrategyInterceptor.java:55)
at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateInterceptor.java:37)
at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterceptor.java:165)
at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:121)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessageReceiver.java:93)
at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:225)
at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispatcher.java:66)
at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:861)
at com.adobe.workflow.engine.SynchronousBranch.handleInvokeAction(SynchronousBranch.java:510)
at com.adobe.workflow.engine.SynchronousBranch.execute(SynchronousBranch.java:888)
at com.adobe.workflow.engine.ProcessEngineBMTBean.continueBranchAtAction(ProcessEngineBMTBean.java:2797)
at com.adobe.workflow.engine.ProcessEngineBMTBean.asyncInvokeProcessCommand(ProcessEngineBMTBean.java:697)
at com.adobe.workflow.engine.EJSLocalStatelessadobe_ProcessEngineBMTEJB_7d3cbd67.asyncInvokeProcessCommand(Unknown Source)
at com.adobe.idp.workflow.dsc.service.ProcessCommandExecutorService.invokeProcess(ProcessCommandExecutorService.java:55)
at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:154)
at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
at com.adobe.workflow.engine.PEInvokeProcessCommand.execute(PEInvokeProcessCommand.java:126)
at com.adobe.workflow.workadapter.WorkflowCommandExecutionUnit.execute(WorkflowCommandExecutionUnit.java:22)
at com.adobe.idp.dsc.workmanager.adapter.ManagedAsynchronousWorkAdapter.run(ManagedAsynchronousWorkAdapter.java:70)
at com.adobe.idp.dsc.workmanager.adapter.websphere.J2WA_Work.run(J2WA_Work.java:34)
at com.ibm.ws.asynchbeans.J2EEContext$RunProxy.run(J2EEContext.java:261)
at java.security.AccessController.doPrivileged(Native Method)
at javax.security.auth.Subject.doAs(Subject.java:337)
at com.ibm.websphere.security.auth.WSSubject.doAs(WSSubject.java:118)
at com.ibm.ws.asynchbeans.J2EEContext$DoAsProxy.run(J2EEContext.java:328)
at com.ibm.ws.asynchbeans.J2EEContext.run(J2EEContext.java:757)
at com.ibm.ws.asynchbeans.WorkWithExecutionContextImpl.go(WorkWithExecutionContextImpl.java:218)
at com.ibm.ws.asynchbeans.ABWorkItemImpl.run(ABWorkItemImpl.java:158)
at com.ibm.ws.util.ThreadPool$Worker.run(ThreadPool.java:1497)
Caused by: java.io.OptionalDataException
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1325)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:348)
at java.util.HashMap.readObject(HashMap.java:1066)
at sun.reflect.GeneratedMethodAccessor15.invoke(Unknown Source)
at java.io.ObjectStreamClass.invokeReadObject(ObjectStreamClass.java:946)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1809)
at java.io.ObjectInputStream.readOrdinaryObject(ObjectInputStream.java:1719)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1305)
at java.io.ObjectInputStream.defaultReadFields(ObjectInputStream.java:1908)
at java.io.ObjectInputStream.readSerialData(ObjectInputStream.java:1832)
at java.util.ArrayList.readObject(ArrayList.java:591)
at sun.reflect.GeneratedMethodAccessor282.invoke(Unknown Source)
at java.io.ObjectInputStream.defaultReadObject(ObjectInputStream.java:479)
at com.adobe.workflow.pat.service.PATExecutionContextImpl.readObject(PATExecutionContextImpl.java:1383)
at java.util.HashMap.readObject(HashMap.java:1067)
at com.adobe.idp.jobmanager.execution.InternalJobManager.deserializeObject(InternalJobManager.java:1348)
... 84 more
Total Likes
