Complied chm file displays 'HTML help' on the title bar instead of the window name.
I tried several ways like:
1. Changed File>Project settings name and also set the language to English (US).
2. Checked the Title name in .hhp file
3. Used the window while compling.
4. Robohelp language settings.
5. Also uninstalled and reinstalled robophelp.
But nothing helped
The title name is displayed correctly if the same project is compiled on another machine.
When the code in the HHP and the regional settings on a PC match, the correct title is displayed. Or other way around is also true the help title is displayed in the language specified in the help project IF (and only if) the regional settings of the PC match that language. Otherwise, "HTML Help" is displayed.
Hope this help.
Thanks and Regards,
Rahul Karn
You can change that in your Window settings. Go to your Project Set-up and choose Windows. Select the Main window. Type whatever you want in the Window Caption. It will appear on the title bar of the compiled help.
I have tried this as mentioned earlier, but no luck .
When the same project is compiled on another machine, the correct title appears.
Hope this help.
Thanks and Regards,
Rahul Karn
Hey Rahul,
I worked :). Thanks a ton for your help.
Vijeta
