SOLVED
Is it possible to remove unwanted alt tags?
Avatar
Level 3
Some of the field boxes on my form show alt tags with the field name that was given.  Is there a way to get rid of the unwanted alt tags for some of the field boxes??  Thanks so much.
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
Go to the Accessibility properties and change the Screen Reader Precedence to 'None'.
Steve
Avatar
Correct answer by
Steve
Avatar
Level 3
Easy enough...thanks for your help.
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
