my LC ES Server 8.2 SP2 (incl. Pdf Generator ES) is running under Linux and I want to get this service working. Testing a .doc, .txt, .jpg with the Workbench (CreatePDF2) as well as with the adminui produces a ALC-PDG-001-000-Error. Although I've installed OpenOffice on the server and set the OpenOffice_PATH environment variable to the install directory (/usr/lib/ooo-2.0/) and not to the executables how it is described in the manual. I think that all the other actions described in the manual are not needed/possible (installing Acrobat and configuring default printer).
What I'm not sure about ist whether under Linux it is also necessary that the install user is the same as the user running the application server (JBoss).
The HTMLToPDF conversion produces the same error - Trying it with an URL or a HTML file.
Is there anything that I can do to get PDF generating working???
Thanks for your help.
Total Likes
We've been having similiar problems with no luck sorting them out.
Has anyone been able to get PDF Generator working on Linux to generate pdfs from even text input?
Total Likes
Hi
Anyone got the solution for this issue. Since we are also got struck with this issue.
OR Still you have the problem since 2009 ..?
Sasikumar
Total Likes
Total Likes
