I've been trying everything I can think of, but I just can't get CFBuilder to work
I just keep getting "Evaluation Expired" from the stand-alone installation
Or not working at all with a similar message for the eclipse plug-in.
I'm guessing that I screwed up when I installed and should have removed any old CFBuilder beta/pre-release installations.
But I didn't, and now I can't get the released CFBuilder to run
(and I'm in deep with a deadline for this week, I guess I need to fire-up my old Dreamweaver to get the job done)
The old license key/file/.. must still linger around somewhere. Does anyone know where, and if I can just delete it.
It seems a bit harsh to have to reinstall my machine to make this work, so there must (I hope and pray) be something I can do?
What I've done:
- [Plug-in] Installed the released CFBuilder ontop of an old existing CFBuilder installation
Result: Didn't work!
- [Plug-in] Uninstalled CFBuilder
- [Plug-in] Reinstalled the released CFBuilder
Result: DIdn't work
- [Plug-in] Started with a fresh Eclipse installation
- [Plug-in] Installed CFBuilder
Result: Didn't work
Please someone HEEELP!!!
/Max
I had the same issue. I guess no one has any solution.
Which sucks!
I just got a new MBP, fresh install of everything on a brand new OS install and I still got the same issue
1. Installed Eclipse
2. Installed some plugins (Suclipse, GAE, ...)
3. Installed Flash Builder 4 as plugin (60 days trial)
4. Installed CFBuilder
And after restarting eclipse and trying something remotly related to CFBuilder I get the popup, stating that my eval license has expired, and there's no way to get out of this mode. I own 2 licenses of CFBuilder and I can't install any of them.
Very, very poor first impression of CFBuilder
/Max
I have sent you about how to resolve it.Please check and let me know if that resolves or not(please mail me).
This should have been the case with the selected pre-release customers who had received the test license key and did not deactivate before March 30th.
Could you send it to me also?
The screen shot that is included is of Beta build which was supposed to expire by march 30 th.
Are you seeing the same issue or is it a different one?
If it is is same issue please uninstall your build and install the release build.
Otherwise please mail me back.
I get a similar message but I'm using Win XP so it's a little different. Notice the "Trial Version Expired" in the title of the window.
Can you please mail me from your e-mail ID with your details?
I too have the same problem. Installed 60 -day evaluation a long while back and expired. Uninstalled and installed again and when I fire it up it quits saying trial expired, not even a chance to enter the license key.
May be you are using Beta release build and not the final release build.Do you want to send the screenshot so that I can help you?
Krishna
I was using the release build but 60 day trial. I now purchased the license.
Uninstalled the older version and reinstalled again.
As soon as i start CFBuilder, it says trial expired, without an option to
enter the license key. I am on a Mac.
Kalyan.
If you can send me the screen shot of the complete error window that you see, I can know what could have happened and so that I can help you accordingly.
By any chance were you pre-release customer?
Krishna
No. I installed the CFB 1.0 and not the prerelease version.
Attached is the screenshot.
Hi Kalyan,
I could not receive the image.Probably you would have replied from your mail.Can you please attach it by opening this thread in the browser.
Or you can can mail me privately to my adobe mail ID that is with my profile.
Krishna
No. I installed the CFB 1.0 and not the prerelease version. Its the same the [Anvil Creative] posted. Here's the screenshot.
Hi Kalyan,
This is the beta build(2009 is there on the splash screen) and not the final release build(2010).Final release build is 271911.If you want to check the build go to plugins folder and check that atleast some jar/folders name ends with 271911.In your case you would see lesser number as you are using beta build.Probably you are on beta build: 263215
Please download the final released build from http://www.adobe.com/cfusion/tdrc/index.cfm?product=coldfusion_builder.
Krishna
Krishna,
Thanks a lot for the clarification. That helped. Uninstalled the previous
version and reinstalled the latest download and its working.
-- Kalyan.
