Hello,
I am desperate to run across anyone who can tell me how to convert my voice that was recorded from a microphone under the "record audio" option in PowerPoint from an MP3 file to one that can be used for publishing. After 2 failed attempts at presentations of 112 slides, I don't know what else to do. It keeps giving me an error message whenever I try to save it after a few slides. It won't let me do anything else until I decide to either erase the files, or magically find what it needs. The thing that kills me is that I have a complete library of my narrarations as MP3s. I am doing this for a grad school project, and need some answers if anyone has them. I'd be so incredibly grateful.
Thank you,
Frazzled, dumbfounded, confused as to why an institution would ask one to do this without any formal training --- other than a hand-out ... which was followed precisely.
Hello,
I do not seem to understand correctly your problem. Did you record from the Presenter plugin (see screenshot) when having the issues or did you try to import MP3-files? If you are recording, there is no need to convert yourself, you get automatically MP3 files that will be stored in the data-folder. What is exactly the error message that you get?
Lilybiri
Yes, I have recorded from the presenter plug in. Whenever I hit publish after finishing up, or even if I go back to the "home" portion of powerpoint after narrarating a few slides, when I try to go back into the recorder, The error message reads ... "Adobe Presenter cannot load the recordings for all slides. The recordings are not in the .ppcx file." "The recordings were last stored in this file" .... it then gives the file name ending with /Media.ppcx. It then gives options including "load the recordings from another file." When I hit browse, it has empty folders. I have the MP3s ... but it will not let me search for those to import. Instead it has it set to the .ppcx. The actual folder has my presentation name on it, but no audio. The other option is to "continue without the recordings on the slides, which erases the audio completely ... even from MP3s. The other option is to cancel and return to the slide show. I have no idea what to do!
If possible, can you send the presentation along with data to vishesh@adobe.com
Wow, I would love to know how this problem was resolved, and what causes it to happen in the first place! I
have had this happen a number of times and it is extremely frustrating.
