You didn’t understand my question, I’m not seeing
the flash images outside of the Breeze window, I’m seeing the
flash animations outside flash defined window, but inside Breeze
window.
Imagine I have a 720 x 540 Breeze window, and in a slide, I
have a flash animation that is 200 x 200. When I publish the
presentation I can see the flash animations outside the 200 x 200
flash window. But inside the 720 x 540 breeze window.
I’m referring to animations like when we make an object
appear in the window, but in his initial position are not visible,
and latter enter in the scene. What is happening is, after
publishing with breeze, is that it is possible to see the object in
his initial position, witch is outside the 200 x 200 flash defined
window.
It is a bit difficult to explain this… I hope you
understand…
