For some reason my libs folder is being ignored, all the swc's have a ? mark over them.
Double check your project properties build path. In the Libary Path tab if "libs" is missing, use "Add SWC Folder...".
Jason San Jose
Software Engineer, Flex Mobile
The "?" icon sounds like SVN/Subclipse to me. Were those files added to your repository?
I done this but still the problem. The file is local to the project and called libs2
yes thats not an issue I'm using SVN
i also have an external src but that shouldn't effect anything?
my mistake, thought my swcs contained the class I was missing
hi nikos,
can you give us some more information...is your libs folder just a local folder in your project (i.e. default one that gets created)? Are you using any sort of linked resources or sym links? Have you tried just refreshing that node in the Package Explorer? Does the compiler find your swcs and compile them and is it just a Package Explorer issue?
thanks,
-george
