Just upgraded from RH7 to RH8 and noticed in all my projects where I have numbered lists, the number, which was blue in RH7 along with the text, is now black in RH8. It's blue in the Design mode but after generating FlashHelp, the numbers are black but the text is still blue. How do I fix this?
In addition, heading 1, which is orange, shows black in Design mode but is orange after generating FlashHelp.
Upgrading to RH8 gives many people similar problems.Please do the following:
1. Run "Upgrade DHTML in Topics" in the Tools menu. (Backup first).
2. Browse the forum for list problems and RH8. Also, be sure to read snippet 25: http://www.grainge.org/pages/authoring/rh8/using_rh8.htm
3. If the previous didn't solve your problem, please share your style sheet and an example topic so we can help you further.
Greet,
Willam
I fixed the issue with heading 1.
Greet,
Willam
The first step didn't work so I reviewed snippet 25 and that worked for the most part. If have a lot of drop down text so some of those items weren't fixed with the search and replace. Thanks.
