Hello
I'm using RH 8. I'm using a lot of "Drop Down", but the problem is, after HTML compilation, that the Research fonction doesn't work on them (impossible to find a word in a drop down). It's a big problem for us !
Does anybody have a solution ?
Hi there
I just tested this and the Search actually does find the terms I search for if they are hidden inside DHTML Drop-Downs.
Are you possibly instead, talking about the fact that the DHTML Drop-Downs where the term(s) appear are not expanded to reveal the term(s)?
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95! |
Hi Captiv8r, thanks for the answer.
Yes, the Research fonction find the correct page, but if the term I search is in a DHTML Drop-down, the DHTML Drop-down stay close. If the Drop-down contains a lot of text, or if there are severals Drop-down in the page, it's too difficult for the user to find the word.
There is a solution ?
In a Webhelp output, if the word is in a drop down, it's underlined (the dropdown stay close). But not in the CHM : the drop down stay close and the word is not underlined. In CHM, is it possible to have the same result as in the Webhelp output ?
Hello again
Unfortunately I don't think this behavior can be changed. It's just not a feature supported in teh CHM format.
Cheers... Rick
