Unable to create Adobe AIR output using RoboHelp 8
Nov 19, 2010 Nov 19, 2010
Hi!
I am unable to create Adobe AIR output from RoboHelp 8. When I compile the project, I receive the following error message. Can someone check and let me know what must be done to create the AIR ouput successfully?
571
Community Expert , Nov 23, 2010 Nov 23, 2010
I'm not familiar with "RoboHelp Packager for RoboHelp AIR" - I've always created AIR help by using the Single Source Layout in RH8. Maybe you should try creating a new AIR SSL layout (don't copy an existing one - create a new one from scratch to eliminate corruption).
To eliminate your project as the cause, try using one of the sample projects & generate AIR help with it. If it works, then you know that your project is at fault; if it doesn't, then something in the RH install is wrong.
Hi!
Thanks for your response. I tried to create Adobe AIR output using one of the sample projects. The same error message was still displayed. I reinstalled RoboHelp 8 and attempted to create the AIR output to see the same error message.
However, I am able to create AIR output from WebHelp of the same project using the RoboHelp Packager for RoboHelp AIR.
Hi Jeff
I think RoboHelp 7 was when Adobe came up with the idea of AIR Help. At the time, it was a separate download and allowed the help author to package a WebHelp output as AIR Help.
RoboHelp 8 had the feature included as part of the main output types.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7 or 8 moments from now - $24.95!
Adobe Certified RoboHelp HTML Training
SorcererStone Blog
RoboHelp eBooks
Nov 24, 2010 Nov 24, 2010
Hi Jeff!
Thank you so much. I once again installed RoboHelp 8 and created the project from scratch. This time I successfully generated the Adobe AIR output.
Thank you once again!
RoboHelp Documentation
Download Adobe RoboHelp
