SOLVED
If calculation
Avatar
Level 2
How can i do the following calculation:
Values/Fields are:
Amount:
[DISCOUNT1] 10
[DISCOUNT2] 20
[DISCOUNT3] 30
Percents:
[DISCOUNTIF1] 1
[DISCOUNTIF2] 2
[DISCOUNTIF3] 3
Total:
[TOTALDISCOUNT]
The calculation should go something like this:
If total amout is over 10[DISCOUNT1] and below 20[DISCOUNT2], the [DISCOUNTIF1] is 1,
If total amout is over 20[DISCOUNT2] and below 30[DISCOUNT3], the [DISCOUNTIF2] is 2,
If total amout is over 30[DISCOUNT3], the [DISCOUNTIF3] is 3.
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
Is this what you are after?
// form1.page1.subform1.discount::calculate - (FormCalc, client)
if (HasValue(totalPrice)) then
  if (totalPrice > 10 and totalPrice < 20) then
    $.rawValue = totalPrice * 0.01
  else
    if (totalPrice > 19 and totalPrice < 30) then
      $.rawValue = totalPrice * 0.02
    else
      if (totalPrice > 29) then
        $.rawValue = totalPrice * 0.03
      endif
    endif
  endif
else
  $.rawValue = null
endif
Steve
1 Reply
Avatar
Correct answer by
  else
    else
      endif
    endif
  endif
else
  $.rawValue = null
endif
Steve
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
