1 Reply Latest reply on Nov 22, 2010 10:29 AM by Flex harUI
    Stack underflow
    llancet Level 1
      on the first line of applyColorToCurrentGenome(), it is:
      var currTheme:Object = colorThemeCombo.selectedItem;
      where colorThemeCombo is a combobox.
      I don't know what caused this error.
      It is a flex3 project, compiled and debugged on FB4.
      My browser is google chrome, and flash player version is 10,1,102,64
      typecheck plugin/applyColorToCurrentGenome()
        outer-scope = [global Object$ flash.events::EventDispatcher$ flash.display::DisplayObject$ flash.display::InteractiveObject$ flash.display::DisplayObjectContainer$ flash.display::Sprite$ mx.core::FlexSprite$ mx.core::UIComponent$ mx.core::Container$ mx.core::LayoutContainer$ mx.core::Application$ plugin$]
                             [plugin[O] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A]] {} ()
        0:debugfile "D:\mydoc\flex\SeqDrawPlugin\src;;plugin.mxml"
        2:debugline 432
        5:getlocal0
                             [plugin[O] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A]] {} (plugin[O])
        6:pushscope
                             [plugin[O] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A]] {plugin[O]} ()
        7:pushnull
                             [plugin[O] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A]] {plugin[O]} (null[O])
        8:coerce SeqGraph.Elements::ElementBase
                             [plugin[O] *[A] *[A] *[A] *[A] *[A] *[A] *[A] *[A]] {plugin[O]} (SeqGraph.Elements::ElementBase?[O])
        10:setlocal3
                             [plugin[O] *[A] *[A] SeqGraph.Elements::ElementBase?[O] *[A] *[A] *[A] *[A] *[A]] {plugin[O]} ()
        11:pushnull
                             [plugin[O] *[A] *[A] SeqGraph.Elements::ElementBase?[O] *[A] *[A] *[A] *[A] *[A]] {plugin[O]} (null[O])
        12:coerce_s
                             [plugin[O] *[A] *[A] SeqGraph.Elements::ElementBase?[O] *[A] *[A] *[A] *[A] *[A]] {plugin[O]} (String?[S])
        13:setlocal 4
                             [plugin[O] *[A] *[A] SeqGraph.Elements::ElementBase?[O] String?[S] *[A] *[A] *[A] *[A]] {plugin[O]} ()
        15:pushbyte 0
                             [plugin[O] *[A] *[A] SeqGraph.Elements::ElementBase?[O] String?[S] *[A] *[A] *[A] *[A]] {plugin[O]} (int[I])
        17:convert_u
                             [plugin[O] *[A] *[A] SeqGraph.Elements::ElementBase?[O] String?[S] *[A] *[A] *[A] *[A]] {plugin[O]} (uint[U])
        18:setlocal 5
                             [plugin[O] *[A] *[A] SeqGraph.Elements::ElementBase?[O] String?[S] uint[U] *[A] *[A] *[A]] {plugin[O]} ()
        20:debug
        27:debug
        34:debug
        41:debugline 433
        44:getlocal0
                             [plugin[O] *[A] *[A] SeqGraph.Elements::ElementBase?[O] String?[S] uint[U] *[A] *[A] *[A]] {plugin[O]} (plugin[O])
        45:getproperty colorThemeCombo
                             [plugin[O] *[A] *[A] SeqGraph.Elements::ElementBase?[O] String?[S] uint[U] *[A] *[A] *[A]] {plugin[O]} (mx.controls::ComboBox?[O])
        48:getproperty selectedItem
                             [plugin[O] *[A] *[A] SeqGraph.Elements::ElementBase?[O] String?[S] uint[U] *[A] *[A] *[A]] {plugin[O]} (Object?[A])
        51:coerce Object
        53:setlocal1
                             [plugin[O] Object?[A] *[A] SeqGraph.Elements::ElementBase?[O] String?[S] uint[U] *[A] *[A] *[A]] {plugin[O]} ()
        54:pop
      VerifyError: Error #1024: 发生堆栈下溢。
      at plugin/applyColorHandler()[D:\mydoc\flex\SeqDrawPlugin\src\plugin.mxml:409]
      at plugin/__colorThemeCombo_change()[D:\mydoc\flex\SeqDrawPlugin\src\plugin.mxml:564]
      at flash.events::EventDispatcher/dispatchEventFunction()
      at flash.events::EventDispatcher/dispatchEvent()
      at mx.core::UIComponent/dispatchEvent()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\co re\UIComponent.as:12266]
      at mx.controls::ComboBox/dispatchChangeEvent()[E:\dev\4.0.0\frameworks\projects\framework\sr c\mx\controls\ComboBox.as:1879]
      at mx.controls::ComboBox/close()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\controls\ ComboBox.as:1651]
      at mx.controls::ComboBox/dropdown_changeHandler()[E:\dev\4.0.0\frameworks\projects\framework \src\mx\controls\ComboBox.as:2137]
      at mx.controls.listClasses::ListBase/mouseUpHandler()[E:\dev\4.0.0\frameworks\projects\frame work\src\mx\controls\listClasses\ListBase.as:10240]
      at mx.controls::List/mouseUpHandler()[E:\dev\4.0.0\frameworks\projects\framework\src\mx\cont rols\List.as:2469]
        • 1. Re: Stack underflow
          Flex harUI Adobe Employee
          Looks like you might be mixing different Flex versions. All SWCs in a
          project must be compiled against the same version.  Also all SWFs loaded
          must be compiled against the same version unless you use Marshall Plan
          techniques.
