I'm doing some .Net integration and the values of the .Net object returned need to be inspected and then displayed if they are defined
I've found that the conversion process brings everything back as rootObject.Get_ObjectName().Get_Value() which blows up if the object is empty throwing an undefined error - However if I try and use isDefined("rootObject.Get_ObjectName") or StructKeyExists(rootObject,"Get_ObjectName) - it just doesn't work - If I add in the () at the end - it blows up Coldfusion
I can't just display everything because there may be elements that are empty - Has anyone else had this problem & have a solution?
It's not bringing back a structure that you can examine with those functions. Instead, just wrap your call to rootObject.Get_ObjectName().Get_Value() in a try/catch block.
Dave Watts, CTO, Fig Leaf Software
http://www.figleaf.com/
http://training.figleaf.com/
Fig Leaf Software is a Veteran-Owned Small Business (VOSB) on
GSA Schedule, and provides the highest caliber vendor-authorized
instruction at our training centers, online, or onsite.
Read this before you post:
http://forums.adobe.com/thread/607238
Thank you - you are a lifesaver - that worked perfectly
You're welcome!
