Hello!
I have installed on my PC Word 2007 and Word 2010. They both work fine.
After I installed Word 2010, i can't create printed documentation any more, because robohelp says that no compatible version is installed.
I know that I can first start Word 2007, so the configuration is rewritten and then it works again. But this process takes a long time. So i deactivated this process with the Registry-Key NoReReg=1.
I suspect that Robohelp Notes from the registry, the current version of Word. The question is, what registry-key is the right one. There are tons that have to do with Office.
Does anyone have an idea, which registry-key Robohelp queries?
Sorry for my bad english!
Greetings!
WEC
I believe someone posted that very recently. A search in the fields for the RoboHelp categories should help.
If you do use Word 2010, bear in mind it is not tested or supported.
