I followed the TwitterTrends tutorial on how to build a mobile android app. I got to the point to debug on the device (phone, mine is Motorolla Droid - Android 2.2 os), and it just doesn't work. Here is what is set up on my phone:
So, my coputer sees my phone (I can browse its directories) and my phone sees my computer. What else could be going wrong?? Not much on the internet about people having problems and seems like it should be easy.
Please let me know if you have any suggestions!!
Peter
What's the error you are seeing and which OS is your computer on?
I got it working - needed to shut down flash builder and restart... The
usual kill it and re-open did the trick.
Was no error, FB just reported it couldn't find a device...
I have the same problem, but the restart didn't work.
Anyone have some other advice?
Make sure you have downloaded and installed the 2.x components of the Android SDK:
http://developer.android.com/sdk/index.html
This was not explicitly mentioned in the Sample Tutorial, but i found out in other blogs/forums. So your computer needs to have this installed separately even though Burrito comes with the android mobile app framework.
Follow the steps that Google provides and install everything you need, takes a while.
Then it will work - i also did a restart, but i think this was the real solution
Let me know how it works!
Pete
No luck...
I installed everything Google wanted to, but it didn't work
Did you check my original post - make sure you have done all the things in the bulleted list.
Some other questions:
1. What phone are you using
2. What type of computer and OS are you using? I was using Dell desktop with Windows XP.
3. Get the IP address from your phone (go into wireless settings, etc..), and be sure your development computer can ping your phone. Even though you are connected via USB, you still need to be visible on the network.
4. Did you install the USB and droid drivers so the phone can communicate with your machine?
Other than that, i am not sure.
Hey all
I had some problems in debugging mobile android app and the reason was that even the laptop and mobile phone was on the same wi-fi somehow they didn't get thru to each other....
What worked for me was that i turned the wi-fi tethering on( Nexus one ) and hooked my laptop to that....after that debugging started working like a charm.
I think that the wi-fi tethering is available in android 2.2 and later...
I did not have to do tethering on my Motorola Driod - but good to know that
is a potential requirement for other phones.
Hey
It's not a requirement but more of like a potential solution for debugging.
wifi tethering -> turns your phone to a wifi router to which a laptop can hook on to and there wouldn't be any strange rules to prevent your debugging.
Sorry I didn't answered earlier.
For some reason my company had all the USB ports blocked and Burrito couldn't write to the device.
I unblocked them and it worked fine
same problem here but I'm using the HTC Desire
I've installed the driver but FB cant connect to the device whether its on debug or run mode.
Windows 7 32 bit.
But does it still add your app to your device ?
and it keeps asking for the debugger location ?
nop, the .apk file doesnt get to the device at all.
I've tried running the app without connecting the device, the builder notified me that no device was connected, so I plugged it again and hit refresh. The device was recognised, I selected it but after running it again, still nothing on the device. :S
is your phone in debug mode ?
yep, the debugging setting is enabled. Flash Pro was communicating with my device perfectly! the problem is with Buritto for some reason.
that's weird...
maybe the usual restart burrito / pc would help...
or check the usb driver installation instructions from adobe site
..cant remember the url now but google...i think i remember that they had instructions how to add the newer android phonesto the usb driver support list...that might be the problem...
My problem, mentioned earlier, was that I did not have all the android SDK
files downloaded from google. This was not explicitly spelled out in the
burrito tutorials. This took a while to download and install, but that
solved it for me.
Just installed the Android SDK (win xp) and still unable to debug from my Nexus One.
The device is properly detected in FB, but shows nothing in the OS Version column.
FB also throws an error "Device's OS is not supported by AIR. Minimum supported OS version is 2.2 (Froyo)".
Seems like a bug in FB because I actually run 2.2 Froyo and AIR is installed on my device.
Anybody encountered that type of behavior?
Double check the OS, as I tried to debug/test on HTC Eris Droid, and it was
dropped from the Android update list - it is stuck forever at 2.1. I
thought it was at 2.2, then I checked and it never got the update.
If yours is really at 2.2 and you installed Adobe Air, check that your phone
is in debug mode and that it is connected to your wireless network.
Thanks pmcalenney1 for your quick response.
Also, please note that Flash Builder is showing the correct AIR version number installed on my device in the configuration menu, but nothing in the OS Version column.
Anything I might have missed?
Thanks in advance
I'm having a similar problem on a Samsung Epic 4G from Sprint, I updated to Froyo manually using an official release from google. For some reason my app (air.com.justinbuser.BuzeyTunes) doesn't show up in the market when I search even though Air itself does and my app runs fine on the device when I install the apk manually. I'm thinking there is some setting in the Android OS somewhere that indicates what the devices capabilities are that for whatever reason doesn't get updated when installing non service provider updates. Ergo I don't believe it's actually an issue with FB so much as an issue with the capabilities reported by the phone.
Interesting. How did you manage to export your Flex app to an apk? Using command line?
My Nexus One is brand new (Videotron), was coming with 2.2, and FB just won't let me export it correctly.
Could this be related to the USB drivers that comes with Flash Builder? Is there some updated version of the file?
Burrito builds the apk automatically every time you choose run/debug on device, it also builds an apk when you export release build. You did create your project using new->mobile application right?
Yes it is a mobile application.
Thing is there is no way for me to run/debug on my device as FB detects lower than 2.2 Froyo and just throws an error.
Did you ever ran into this. Is there any other way to generate my apk file using Flex's SDK? (without Flash Builder)
