30 Replies Latest reply on Mar 9, 2018 9:42 PM by Colin Flashman
    Possible to Delete Empty Text Frames via a Script?
    kmc27 Level 1
      I've seen a few posts on similar topics, but I'm not sure if they were exactly the same. I am running Mac OS 10.5.8, InDesign CS 4 ver 6. Often our InDesign documents start (from an XML load into a InDesign template) with some empty text frames that we end up manually deleting. I saw the script below on these forums and gave it a try to automate deleting the empty frames - it looks like it should do what I need, but I get this error:
      JavaScript Error!
      Error Number: 1
      Error String: contentType
      File: Applications/Adobe InDesign CS4/Scripts/Scrips Panel/RemoveEmptyFrames.jsx
      Line: 7
      Source: if (myTextFrames[0].contents == "") myTextFrames[0].conentType = ContentType.UNASSIGNED.
      Does anyone have advice on how to make this work?
      var myStories = app.activeDocument.stories.everyItem().getElements();
      for (i = myStories.length - 1; i >= 0; i--){
          var myTextFrames = myStories[i].textContainers;
          for (j = myTextFrames.length - 1; j > 0; j--)    {
              if (myTextFrames[j].contents == "") myTextFrames[j].remove();
          if (myTextFrames[0].contents == "") myTextFrames[0].contentType = ContentType.UNASSIGNED;
        • 1. Re: Possible to Delete Empty Text Frames via a Script?
          Peter Spier Most Valuable Participant (Moderator)
          Not sure what else might be wrong, but you've got unbalanced curly braces ...
          • 2. Re: Possible to Delete Empty Text Frames via a Script?
            Harbs. Level 6
            That does not delete all empty frames. It keeps the first frame and converts it to an unassigned graphic frame. If it's tagged as an xml story, that might not work...
            Harbs
            • 3. Re: Possible to Delete Empty Text Frames via a Script?
              kmc27 Level 1
              All the frames on the documents I have are xml tagged, but I'd like to be able to delete just the ones that are empty via scripting. Does this mean that if a text frame is xml tagged, it can only be deleted manually?
              • 4. Re: Possible to Delete Empty Text Frames via a Script?
                Harbs. Level 6
                No. Try this instead:
                    for (j = myTextFrames.length - 1; j >= 0; j--)    {
                        if (myTextFrames[j].contents == ""){
                Harbs
                • 5. Re: Possible to Delete Empty Text Frames via a Script?
                  rob day Adobe Community Professional & MVP
                  Shane Stanley posted this elegant 1 line AppleScript awhile back:
                  tell application "Adobe InDesign CS5"
                       try
                            delete (every item of all page items of every page of document 1 whose class is text frame and contents = "" and name of fill color = "None" and name of stroke color = "None")
                       end try
                  end tell
                  • 6. Re: Possible to Delete Empty Text Frames via a Script?
                    kmc27 Level 1
                    Thanks for your help on this. I did some testing with Harbs script and am not sure what to make of the results. The content on my InDesign documents are created via an XML import, and maybe that makes a difference.
                    Here is what I found:
                    1. Empty frames created from the XML import remain on the page
                    2. Overset frames created from the the XML import are deleted.
                    3. If I manually created a Text Frame via the Type Tool and it is empty, it is deleted
                    I tested further and found that if I go into the structure pane and delete the empty text frame element and then run the script, the empty text frames are then deleted.
                    Is there something in the XML created text frames that appears as content to the script?
                    An example page is here
                    • 7. Re: Possible to Delete Empty Text Frames via a Script?
                      This almost seems like a bug at least with AppleScript
                      If I make and loop through a list of every text frame with an XML tag, and then test with an if statement checking for "" content, the if statement doesn't run even when the "" contents return as true:
                      --get a list every tagged text box
                      set myXML to every item of all page items of every page of document 1 whose class is text frame and associated XML element is not nothing
                      repeat with i in myXML
                      --even when the contents is equal to "" the delete doesn't happen
                      if contents of item 1 of i is equal to "" then
                      beep
                      delete i
                      end if
                      end repeat
                      end tell
                      • 8. Re: Possible to Delete Empty Text Frames via a Script?
                        kmc27 Level 1
                        Does this mean that XML generated Text Frames have some value that a Text Frame created with the Type Tool does not?
                        • 9. Re: Possible to Delete Empty Text Frames via a Script?
                          It looks like the XML tags are considered content even when there are no characters in the text box, so if I run a script to count the characters in every text box TextBox4 shows 4 characters even though it is empty on the page. If I delete the Exclusion_Notes tag the character count is 0.
                          Try this script which worked on your sample (it looks for 0 words):
                          try
                          set theframes to every item of all page items of every page of document 1 whose class is text frame and name of fill color = "None" and name of stroke color = "None"
                          repeat with x in theframes
                          if (count of words of x) is 0 then
                          delete x
                          end if
                          end repeat
                          end try
                          end tell
                          • 10. Re: Possible to Delete Empty Text Frames via a Script?
                            kmc27 Level 1
                            Hi Rob
                            Thanks so much for your help on this. Your solution worked perfectly - the script now deletes all empty frames.
                            I used the find/change example provided in the InDesign scripting examples in an attempt determine if I could edit your script to delete both empty text frames (as in the script you provided) and also the text frames that have the character format of "bt glyphs". I've found I am just going in circles. Do you think you could take a look at this one more time for me to see if it can be made to delete the empty text frames AND all text frames that have the character format of "bt glyphs"?
                            I can identify them frames via a search in InDesigns Find/Change window and the criteria below.
                            Go to Edit > Find/Change
                            Select the "Text" tab
                            Click the "Specify Attributes to Find" button and choose:
                            Basic Character Formats
                            Font Family "BT Glyphs"
                            Font Style "Regular"
                            I believe those frames can be identified via a findtype of "text" containing the properties of font family "bt glyphs" and font style "regular" (got that from the Adobe's InDesign scripting examples), but I am not able to get the results I want.
                            Any (additional) help you can provide would be greatly appreciated.
                            • 11. Re: Possible to Delete Empty Text Frames via a Script?
                              see if this works:
                                   try
                                                  delete x
                                             else
                                                  --note the tell is to ID not the document
                                                       --clear find prefs
                                                       set find text preferences to nothing
                                                       set applied character style of find text preferences to character style "bt glyphs" of document 1
                                                       if (find text) is not {} then
                                                            delete x
                                                       end if
                                                       --reclear find prefs
                                                  end tell
                                             end if
                                        end repeat
                                   end try
                              end tell
                              • 12. Re: Possible to Delete Empty Text Frames via a Script?
                                Reading your post again I see that you are looking for text with a font applied. My script is searching for a character style named bt glyphs, so it's not going to work as I posted it.
                                Do you want to delete the frame if there is any character with the font BT Glyph applied? Or, does all of the text need to have the font applied before the frame is deleted?
                                • 13. Re: Possible to Delete Empty Text Frames via a Script?
                                  This one looks for the BT Glyph font—if there's any character in the frame with that font the frame is deleted:
                                  try
                                  delete x
                                  else
                                  --set find prefs
                                  set font style of find text preferences to "Regular"
                                  set applied font of find text preferences to "BT Glyphs"
                                  delete x
                                  end if
                                  --reset find prefs
                                  end tell
                                  end if
                                  end repeat
                                  end try
                                  end tell
                                  • 14. Re: Possible to Delete Empty Text Frames via a Script?
                                    kmc27 Level 1
                                    Hi Rob
                                    Thanks. I ran the second script. It does remove the Text Frames with the bt glyphs font, but also deletes all the Text Frames. I found that it:
                                    Deletes overset Text Frames are deleted even though they are not empty - I probably did notice this the first time I tried the script.
                                    The exeception is that I do want to delete any text frames using the bt glyphs font, whether those frames are overset or not.
                                    Deletes Text Frames that use another font other than bt glyphs
                                    The text preferences criteria called for in the script match what I set up via the Edit > Find/Change dialogue box. Using the Find/Change dialogue box results in only those Text Frames using the BT Glyphs font being "found", so it seems that criteria should hold for the script too.
                                    Is there some other criteria I should use to identify the bt glph text frames?
                                    • 15. Re: Possible to Delete Empty Text Frames via a Script?
                                      Sorry, I should have tested before I posted the last one. This seems to work—also handles frames that have an overflow:
                                      try
                                      if (count of words of x) is 0 and overflows of x is false then
                                      delete x
                                      else
                                      --set find prefs
                                      set ftext to find text
                                      if ftext is not {} then
                                      delete parent of item 1 of ftext
                                      end if
                                      --reset find prefs
                                      end tell
                                      end if
                                      end repeat
                                      end try
                                      end tell
                                      • 16. Re: Possible to Delete Empty Text Frames via a Script?
                                        kmc27 Level 1
                                        Rob
                                        Thanks so much for your time and effort in making this work. Your last version does the trick. I had attempted to get the script working by referring to the Adobe InDesign Scripting Guide, but after comparing the non-working vs the latest working script, I can see that I wasn't even close.
                                        Again, I really appreciate your sharing your time and expertise.
                                        Kenn
                                        • 17. Re: Possible to Delete Empty Text Frames via a Script?
                                          camilo umana Level 1
                                          Rob:
                                          Could you please help with this message coming form your script?
                                          IDCS5/7.0.4
                                          • 18. Re: Possible to Delete Empty Text Frames via a Script?
                                            [Jongware] Most Valuable Participant
                                            You copied the script into TextEdit on the Mac. By default, TextEdit saves new files as RTF (formatted) text, and a script should be saved as plain text, without any formatting.
                                            Look in your menus,  there should be an option "Convert to Plain Text" somewhere.
                                            • 19. Re: Possible to Delete Empty Text Frames via a Script?
                                              Uh. That's for Javascript, actually. I don't know if Applescript needs a similar treatment.
                                              • 20. Re: Possible to Delete Empty Text Frames via a Script?
                                                Thank you.
                                                Will try via AppleScript editor
                                                • 21. Re: Possible to Delete Empty Text Frames via a Script?
                                                  Jong:
                                                  You were absolutely right. I copy-pasted the original script in AppleScript app. ( with extension .scpt) and FINALLY this splendid script felt tuned.
                                                  • 22. Re: Possible to Delete Empty Text Frames via a Script?
                                                    dieke12
                                                    Hello,
                                                    I copied this into vbs file :
                                                    (and other versions of code in this forum to delete empty textframes in InDesign 5/Win) .
                                                    [nothing before, nothing after]
                                                    However, when running, any of these proposed solutions, i keep getting Error Msg 'End of instruction is expected'
                                                    I'm completely new to scripts, yet eager to learn. Can anyone point me to where the basics are to be found?
                                                    Does anything need to be added to this copied text, either before or after?
                                                    Thanks ahead for any insights
                                                    • 23. Re: Possible to Delete Empty Text Frames via a Script?
                                                      That code looks to me like javascript....
                                                      • 24. Re: Possible to Delete Empty Text Frames via a Script?
                                                        Laubender Adobe Community Professional & MVP
                                                        This is by no means a script for VBS.
                                                        It's ExtendScript, Adobe's flavor of JavaScript for InDesign.
                                                        So run it as an ExtendScript: Put it in a text-only file and safe it with a *.jsx suffix.
                                                        To make it available in the Scripts panel see here:
                                                        How to Install InDesign & InCopy Scripts - Dan Rodney
                                                        Uwe
                                                        • 25. Re: Possible to Delete Empty Text Frames via a Script?
                                                          dieke12 Level 1
                                                          Thanks Uwe,
                                                          Get different error message now, but at least now i understand how  and where it should be working, with jsx,
                                                          That gives me enough confidence to try the various options listed on this forum. Progressing
                                                          Dieke
                                                          • 26. Re: Possible to Delete Empty Text Frames via a Script?
                                                            dieke12 Level 1
                                                            Thanks Peter, with Uwes post below I have a clue of what your answer implies. Complete beginner, but thanks anyway.
                                                            Dieke
                                                            • 27. Re: Possible to Delete Empty Text Frames via a Script?
                                                              dieke12 Level 1
                                                              Wow! They are all gone! In thin blue air! This opens up a whole new level of game. Thanks guys!
                                                              Dieke
                                                              • 28. Re: Possible to Delete Empty Text Frames via a Script?
        agopaul Level 1
        I wrote a similar script which also deletes Text Frames containing only non visible characters (spaces, tabs, returns, etc).
        Here is the link: https://redokun.com/public/download/scripts/delete-empty-text-frames.jsxbin.zip
        Paolo
        • 29. Re: Possible to Delete Empty Text Frames via a Script?
        Altimages Level 1
        This is a great script. Is there a way to delete text boxes based on a certain color? For example, I made some boxes that I call out as 99% black and some get filled with white text and some don't (Using variable data). I would like to delete the boxes that don't get text in them automatically with a script. Thanks!
        • 30. Re: Possible to Delete Empty Text Frames via a Script?
        Colin Flashman Adobe Community Professional
        I too have an empty frame remover script that is free and in the public domain: https://colecandoo.com/2015/01/23/updated-empty-frame-remover-1-1/
        In answer to your particular question about empty frames that are a particular colour, have a look at this thread: Javascript to delete all empty text boxes filled with a certain color
