You need to give the developers everything that is in the
folder to which you generated. That is defined in the first page of
the wizard. Sometimes developers will ask if everything is needed
to which the stock answer is "only if you want it to work".
RH first tries to access online help. If it cannot, it should
open a local version. If that is not happening, go to Tools |
Options and select Use Offline Help.
