Hi I cannot install Flash Builder Burrito.
OS is Windows Vista 64
I also have CS5 Web Premium installed.
Please help!
Here is what I get:
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 0 fatal error(s), 15 error(s), 16 warning(s)
WARNING: Payload {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX is already installed and the session payload {0B0C731E-5584-4980-A0D2-4ADC89220426} Adobe Flash Player 10 ActiveX has no upgrage/conflict relationship with it.
WARNING: Payload {177E1CA1-14CC-4398-AB15-A5746EFE8F22} Adobe Flash Builder is already installed and the session payload {45CDBACA-8B52-4DAE-9601-287907A155BF} Adobe Flash Builder has no upgrage/conflict relationship with it.
WARNING: Payload {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin is already installed and the session payload {A05D4EC5-033E-4446-9D96-1698FE490147} Adobe Flash Player 10 Plugin has no upgrage/conflict relationship with it.
WARNING: Warning: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding will not be repaired, due to updated patch of STI and one of the top level payload is being installed.
WARNING: Payload cannot be installed due to dependent operation failure
ERROR: Verifying payload integerity : Failed with code 1
ERROR: MsiConfigureProductEx failed with error: 1612
ERROR: The following payload errors were found during install:
ERROR: - Microsoft_VC90_ATL_x86: Install failed
ERROR: - Microsoft_VC90_CRT_x86: Install failed
ERROR: - Microsoft_VC80_ATL_x86: Install failed
ERROR: - AdobeHelp: Install failed
ERROR: - Adobe Flash Builder: Install failed
ERROR: - Microsoft_VC90_MFC_x86: Install failed
ERROR: - Suite Shared Configuration CS5: Install failed
ERROR: - AdobeTypeSupport CS5: Install failed
ERROR: - Microsoft_VC80_CRT_x86: Install failed
ERROR: - AdobeCMaps CS5: Install failed
ERROR: - Microsoft_VC80_MFC_x86: Install failed
ERROR: - Microsoft_VC80_MFCLOC_x86: Install failed
Based on where the errors start in the log, the installer was unable to update Visual Studio runtimes.
There's a KB article here describing how to troubleshoot that by installing those runtimes manually:
http://kb2.adobe.com/cps/842/cpsid_84252.html
After resolving the VS runtime issues, please uninstall FB burrito, reboot the machine and then reinstall FB burrito.
Please run Burrito installer with administrator privileges.
The steps for running as an Administrator differ depending on your version of Windows:
On WinXP:
- it's best to be logged in as a machine Admin during installation
- alternatively you can right click the exe, choose "Run as...", and then authenticate as a user with Admin rights.
On Vista and Win7:
- right click the installer and choose "Run as administrator..."
- [aside: usually Vista and Win7 will prompt for elevated rights automatically, but if you have UAC disabled, it might require manual intervention.]
Deeptika
