1. Re: Export Book as SWF with script?
Petteri_Paananen Nov 25, 2010 10:59 AM (in response to Petteri_Paananen)Like this script but instead of JPEGs it would produce SWFs
2. Re: Export Book as SWF with script?
Marijan Tompa Nov 25, 2010 11:04 AM (in response to Petteri_Paananen)Hi Petteri!
I just tried to export Book to SWF, but it gives me error:
"Book export is not supported by the desired export format..."
tomaxxi
3. Re: Export Book as SWF with script?
Petteri_Paananen Nov 25, 2010 11:35 AM (in response to Marijan Tompa)Shoot! I new it´s not gonna be that easy...=(
Thanks anyway.....
4. Re: Export Book as SWF with script?
Marijan Tompa Nov 25, 2010 12:17 PM (in response to Petteri_Paananen)But your second request can be done.
You can export each spread to separate SWF,
all you have to do is to loop through file and for each export change swfExportPreferences.pageRange.
tomaxxi
5. Re: Export Book as SWF with script?
jaykincer Feb 24, 2011 11:50 AM (in response to Marijan Tompa)I am also looking for a script that can export a book as a swf...
6. Re: Export Book as SWF with script?
borrmart Mar 22, 2011 2:20 AM (in response to Petteri_Paananen)Look here
http://www.publicarendigital.com/2010/05/exportar-de-indesign-swf-pagina-pagina.html
I've used with Indisign CS4 and working properly, in order to specify the value of export to first make one manually. The path where the file is left of the document itself.
Greetings from Spain
